This is something I’ve noticed on multiple systems and hardware. Using the Menu Bar, accessing the Applications category listings works fine generally with the exception of the Office section, which halts or hangs for a few seconds while doing something before showing the apps available in that section. No other categories seem to do this for me.
Any idea what is causing this? More importantly any way to fix this behavior? Because word processing is a typical use for a desktop or laptop and the slow down is a paper cut that impacts the perception of the overall system speed.
Is this as common as I think it is or am I the only one experiencing it?
