Wifi issue in 17.04
I had to do the following before a connection could be made.
sudo nano /etc/NetworkManager/NetworkManager.conf
and add this line to fix wifi issue
[device]wifi.scan-rand-mac-address=no
Plus the other fixes listed above to resolve DNS issues
Did any of these help?
Thanks, but I don’t want to mess about, it doesn’t usually work anyway. I’ll wait until they release a fix and stay on 16.10.
I tried Ubuntu Gnome and Ubuntu Budgie and found the same problem, so I decided I would have to ā€œmess aboutā€ after all. It didn’t work, but I found a similar suggestion on launchpad which suggested that it was also necessary to type:
sudo service network-manager restart
I tried that on an Ubuntu Budgie live CD and it worked, so I installed Budgie and repeated both the above, it still works! Budgie hasn’t got the missing window decoration problem I’ve had with Ubuntu MATE either, so I’m sticking with it.
check it working for me last time
