this may be a foolish assumption, but I think the Ubuntu MATE team are making a version for the new Pi, so it may come either when the new Ubuntu MATE comes out or 16.04, only later.
I hope this helped,
Tails’s reply
P.S: Enter my artwork competition(Memes are almost finished
Perhaps you could give more detail - some other distros seem to boot with no trouble, but may have driver or RPI firmware issues.
Do you really mean 'fails to boot', or is it displaying power power problems on boot, or is it merely booting but failing to get to a working desktop?
Derek
Had the same issue. Hours wasted trying to get it to run. Think they need to put a notice up on the download page that it’s not ready for the pi 3 plus just yet.
Same here. Apparently it’s because of the different processor. And I can’t run php7.1 or 7.2 on rapbian so this caused me to also downgrade my app to an older version of the framework so even more work.
Same issue here. Boots to rainbow screen with low voltage indicator but I’m using the official supply which works fine with my model B. This post indicates this is not actually a power issue, it’s a boot code issue. Wish I’d just bought another model B instead!
I’m reporting the same issue - your not making it past the SD card valid check. Power LED is on , no activity reading from SD.
There is new hardware as well as the Full MKS GL video mode. What I’m disappointed in is no one seemed ready for this obvious change. Pi day every year new hardware, a new image is needed.
Help me Obi Wan your our only hope. Can anyone provide a time frame that isn’t months away?
I installed Raspbian and then copied the files from that installation. I see that 18.04 is out now with a RPi download. I haven’t tried it but I would imagine that upgrading to that would also work.
I installed Rasbian on another microSD card and the Raspbian was working ok. I then copied the /lib/firmware/brcm files to my hd and then transfered them to the other microSD which has Ubuntu Mate 16.04 to the same location. When I put the microSD into the pie and booted, it is stuck with the rainbow screen and the red led is blinking.
I will try copying the boot files from the raspbian to the ubuntu mate boot partition and see if that works. Also in another thread someone mentioned swapping the kernel with the raspian one. If I can’t get it to work, I will abandom this until they come up with a version that works and try ubuntu core in the mean time.
I too have the Pi 3B+ and have managed to run 16.04, but after so so much hard work and even then there were glitches such as no WiFi although it’s enabled. Really it’s not worth the bother until the ‘powers that be’ actually mod a version that will cope with the 64bit processor. Hope this helps
