I am not quite sure if this is the right forum section, lets try.
So this is my setup:
-Ubuntu Mate 16.04.3 (Fresh install)
-Gigabyte Geforce GTX 1050
-Nvidia proprietary driver: 384.111 (exactly same problem with newer drivers)
-Kernel: 4.13.0-32-generic
-Xorg version: 1.19.5
-Dual monitor, main monitor on right. Left monitor is screen (desktop) 1, Right monitor is screen (desktop) 0 (This is how nvidia settings display them, so let’s use these.)
-Separate x screen (set via Nvidia settings GUI program)
-No compiz activated yet (left as is after the fresh install)
I need two separate working desktops, need two independent compiz cubes.
I have it working somehow, desktop #0 (right / main) works fine, but desktop #1 (Left) is the problem. If I try to start anything via taskbar menu on desktop #1, it starts on desktop #0
Workaround is to start terminal, and run (for example start Firefox):
DISPLAY=:0.1 firefox
It starts okay on desktop #1 and everything works.
Obviously this is not what I want
I can not start anything with my mouse, when clicking button 2 on desktop #1.
There is also background image missing. So something is not starting on second (left / #1) desktop.
Last combo that I can get separate X screen to work was Mint 17.2 Mate, and before that very old Ubuntu (Gnome). None of the newer Mint or Ubuntu I tried works perfectly. I decided to use Ubuntu Mate now, since it is almost working, and I do like the look and feel of it.
Here is the current /etc/X11/xorg.conf
# nvidia-settings: X configuration file generated by nvidia-settings# nvidia-settings: version 361.42 (buildd@lgw01-18) Tue Apr 5 14:33:28 UTC 2016
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 1920 0
Screen 1 "Screen1" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Acer AL2423W"
HorizSync 31.0 - 81.0
VertRefresh 56.0 - 75.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor1"
ModelName "Samsung SMS27A650"
HorizSync 30.0 - 81.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce GTX 1050"
BusID "PCI:1:0:0"
Screen 0
EndSection
Section "Device"
Identifier "Device1"
Driver "nvidia"
BusID "PCI:1:0:0"
Screen 1
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-0"
Option "metamodes" "DVI-D-0: nvidia-auto-select +0+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Device1"
Monitor "Monitor1"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-2"
Option "metamodes" "DP-0: nvidia-auto-select +0+0"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
Please ask what you need to know. Or tell me if you had similar problem, and know how to fix it
