18.04 cupertino Shortcuts
How do you create Launchers to Plank when using Cupertino?
If you click on the MENU Icon it covers Plank so you can’t drag the ICON to it.
I can’t seem to find another way to make a shortcut on plank.
Hi: I usually launch the app and right click the icon when it appears on plank. If I can’t minimize the app to show plank, I pull the mouse pointer down to where plank is on the screen to reveal. Can’t remember If I have plank set to intelli-hide or auto hide, but think works with either. Hope this helps.
Thanks will give that a try.
