Hello,
As I am trying to integrate a UM 18.10 VM onto the corporate network I am required to install/use CNTLM so I can access the corporate proxy and then use my VM.
Before going further, I would like to mention that I have probably already checked most of the online references (askubuntu, serverfault, superuser, linuxforums, etc) for this particular problem and even though I was able to learn more I am still stuck and hence now think it could be UM 18.10 related/isolated.
Here are the macro steps that I have covered in order to get CNTLM going:
Installed cntlm and libc6 (it's req);
Ref.: http://cntlm.sourceforge.net/ -
Generated my hashes using cntlm -H;
Updated /etc/cntlm.conf with new informations;
Ref.: https://stackoverflow.com/questions/9181637/how-to-fill-in-proxy-information-in-cntlm-config-file -
Restarted/tested.
Here is how it looked like from a terminal perspective:
The package is properly installed:
$ which cntlm /usr/sbin/cntlm
Let's understand CNTLM's options (FYI):
$ /usr/sbin/cntlm -h CNTLM - Accelerating NTLM Authentication Proxy version 0.92.3 Copyright (c) 2oo7-2o1o David Kubicek This program comes with NO WARRANTY, to the extent permitted by law. You may redistribute copies of it under the terms of the GNU GPL Version 2 or newer. For more information about these matters, see the file LICENSE. For copyright holders of included encryption routines see headers. Usage: /usr/sbin/cntlm [-AaBcDdFfgHhILlMPpSsTUuvw] [:] ... -A [/] ACL allow rule. IP or hostname, net must be a number (CIDR notation) -a ntlm | nt | lm Authentication type - combined NTLM, just LM, or just NT. Default NTLM. It is the most versatile setting and likely to work for you. -B Enable NTLM-to-basic authentication. -c Configuration file. Other arguments can be used as well, overriding config file settings. -D [/] ACL deny rule. Syntax same as -A. -d Domain/workgroup can be set separately. -f Run in foreground, do not fork into daemon mode. -F NTLM authentication flags. -G User-Agent matching for the trans-isa-scan plugin. -g Gateway mode - listen on all interfaces, not only loopback. -H Print password hashes for use in config file (NTLMv2 needs -u and -d). -h Print this help info along with version number. -I Prompt for the password interactively. -L [:]:: Forwarding/tunneling a la OpenSSH. Same syntax - listen on lport and forward all connections through the proxy to rhost:rport. Can be used for direct tunneling without corkscrew, etc. -l [:] Main listening port for the NTLM proxy. -M Magic autodetection of proxy's NTLM dialect. -N "[, " List of URL's to serve direcly as stand-alone proxy (e.g. '*.local') -O [:] Enable SOCKS5 proxy on port lport (binding to address saddr) -P Create a PID file upon successful start. -p Account password. Will not be visible in "ps", /proc, etc. -r "HeaderName: value" Add a header substitution. All such headers will be added/replaced in the client's requests. -S Enable automation of GFI WebMonitor ISA scanner for files < size_in_kb. -s Do not use threads, serialize all requests - for debugging only. -U Run as uid. It is an important security measure not to run as root. -u [@<domain] Domain/workgroup can be set separately. -v Print debugging information. -w Some proxies require correct NetBIOS hostname. $
Before deploying, let's create NTLM compatibles hashes and then apply them in /etc/cntlm.conf:
$ cntlm -u USERNAME -d CORPDOMAIN -H Password: PassLM 97B1A354A90C182DAC8257D627CAF75F PassNT FA50CC02F904F07A6974E23EAE20E660 PassNTLMv2 25123DF21534B37C15FD77AA87B2CE97 # Only for user 'USERNAME', domain 'CORPDOMAIN' $ sudo vi /etc/cntlm.conf # # Cntlm Authentication Proxy Configuration # # NOTE: all values are parsed literally, do NOT escape spaces, # do not quote. Use 0600 perms if you use plaintext password. # Username USERNAME Domain CORPDOMAIN # NOTE: Use plaintext password only at your own risk # Use hashes instead. You can use a "cntlm -M" and "cntlm -H" # command sequence to get the right config for your environment. # See cntlm man page # Example secure config shown below. # PassLM 1AD35398BE6565DDB5C4EF70C0593492 # PassNT 77B9081511704EE852F94227CF48A793 # Only for user 'USERNAME', domain 'CORPDOMAIN' PassLM 97B1A354A90C182DAC8257D627CAF75F PassNT FA50CC02F904F07A6974E23EAE20E660 PassNTLMv2 25123DF21534B37C15FD77AA87B2CE97 # Specify the netbios hostname cntlm will send to the parent # proxies. Normally the value is auto-guessed. # # Workstation netbios_hostname # List of parent proxies to use. More proxies can be defined # one per line in format : # Proxy PROXY1HOST:PROXY1PORT Proxy PROXY2HOST:PROXY2PORT # List addresses you do not want to pass to parent proxies # * and ? wildcards can be used # NoProxy localhost, 127.0.0.*, 10.*, 192.168.*, 192.197.*, 172.16.* # Specify the port cntlm will listen on # You can bind cntlm to specific interface by specifying # the appropriate IP address also in format : # Cntlm listens on 127.0.0.1:3128 by default # Listen 9669 # If you wish to use the SOCKS5 proxy feature as well, uncomment # the following option. It can be used several times # to have SOCKS5 on more than one port or on different network # interfaces (specify explicit source address for that). # # WARNING: The service accepts all requests, unless you use # SOCKS5User and make authentication mandatory. SOCKS5User # can be used repeatedly for a whole bunch of individual accounts. # #SOCKS5Proxy 8010 #SOCKS5User dave:password # Use -M first to detect the best NTLM settings for your proxy. # Default is to use the only secure hash, NTLMv2, but it is not # as available as the older stuff. # # This example is the most universal setup known to man, but it # uses the weakest hash ever. I won't have it's usage on my # conscience. :) Really, try -M first. # #Auth LM #Flags 0x06820000 # Enable to allow access from other computers # #Gateway yes # Useful in Gateway mode to allow/restrict certain IPs # Specifiy individual IPs or subnets one rule per line. # #Allow 127.0.0.1 #Deny 0/0 # GFI WebMonitor-handling plugin parameters, disabled by default # #ISAScannerSize 1024 #ISAScannerAgent Wget/ #ISAScannerAgent APT-HTTP/ #ISAScannerAgent Yum/ # Headers which should be replaced if present in the request # #Header User-Agent: Mozilla/4.0 (compatible; MSIE 5.5; Windows 98) # Tunnels mapping local port to a machine behind the proxy. # The format is :: # #Tunnel 11443:remote.com:443 :wq $
As we can see from above, the only options that were added were:
Username USERNAME
Domain CORPDOMAIN
Listen 9669
I have also appended some LAN prefixes @ "NoProxy localhost, 127.0.0., 10., 192.168., 192.197., 172.16.*" but that is irrelevant.
Let's start the service and see if it connects:
$ sudo cntlm -u USERNAME -I -v [sudo] password for USERNAME: section: global, Domain = 'CORPDOMAIN' section: global, PassLM = '97B1A354A90C182DAC8257D627CAF75F' section: global, PassNT = 'FA50CC02F904F07A6974E23EAE20E660' section: global, PassNTLMv2 = '25123DF21534B37C15FD77AA87B2CE97' section: global, Proxy = 'PROXY1HOST:PROXY1PORT' section: global, Proxy = 'PROXY2HOST:PROXY2PORT' section: global, NoProxy = 'localhost, 127.0.0.*, 10.*, 192.168.*, 192.197.*, 172.16.*' section: global, Listen = '9669' Default config file opened successfully cntlm: Cannot bind port 9669: Address already in use! Adding no-proxy for: 'localhost' Adding no-proxy for: '127.0.0.*' Adding no-proxy for: '10.*' Adding no-proxy for: '192.168.*' Adding no-proxy for: '192.197.*' Adding no-proxy for: '172.16.*' No proxy service ports were successfully opened. Exitting with error. Check daemon logs or run with -v. $
From what we can see above it loaded but there is an error? Also, we have already specified -v so this echo doesn't make sense.
And According to UM 18.10 CNTLM is running:
$ sudo service cntlm status [sudo] password for USERNAME: ● cntlm.service - LSB: Authenticating HTTP accelerator for NTLM secured proxies Loaded: loaded (/etc/init.d/cntlm; generated) Active: active (running) since Mon 2019-03-11 13:33:51 EDT; 44min ago Docs: man:systemd-sysv-generator(8) Process: 753 ExecStart=/etc/init.d/cntlm start (code=exited, status=0/SUCCESS) Tasks: 1 (limit: 4659) Memory: 1.1M CGroup: /system.slice/cntlm.service └─785 /usr/sbin/cntlm -U cntlm -P /var/run/cntlm/cntlm.pid [...] $ cat /var/run/cntlm/cntlm.pid 785 $ ps -ef | grep -i 785 cntlm 785 1 0 13:33 ? 00:00:00 /usr/sbin/cntlm -U cntlm -P /var/run/cntlm/cntlm.pid USERNAME 3406 3298 0 14:06 pts/2 00:00:00 grep --color=auto -i 785 $ sudo ss -tulpn | grep :9669 tcp LISTEN 0 5 127.0.0.1:9669 0.0.0.0:* users:(("cntlm",pid=785,fd=4)) $
But apt is still unable to authenticate on the proxy:
$ sudo apt update Err:1 http://archive.canonical.com/ubuntu cosmic InRelease 407 Proxy Authentication Required [IP: PROXYHOST PROXYPORT] Err:2 http://security.ubuntu.com/ubuntu cosmic-security InRelease 407 Proxy Authentication Required [IP: PROXYHOST PROXYPORT] Err:3 http://ca.archive.ubuntu.com/ubuntu cosmic InRelease 407 Proxy Authentication Required [IP: PROXYHOST PROXYPORT] Err:4 http://ca.archive.ubuntu.com/ubuntu cosmic-updates InRelease 407 Proxy Authentication Required [IP: PROXYHOST PROXYPORT] Err:5 http://ca.archive.ubuntu.com/ubuntu cosmic-backports InRelease 407 Proxy Authentication Required [IP: PROXYHOST PROXYPORT] Reading package lists... Done
So my question is: did anybody ever used CNTLM recently? If so, would you happen to have any tips and hints as right now I am blaming UM and (sadly) am considering deploying another flavor.
Please advise/Thanks in advance,
DLS
PS:
$ uname -a Linux HOSTNAME 4.18.0-10-generic #11-Ubuntu SMP Thu Oct 11 15:13:55 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux $
