When I ran dmesg in the terminal, I got this:
[ 1.440009] nvidia 0000:01:00.0: enabling device (0406 -> 0407)
[ 1.440221] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 1.440457] scsi host0: ahci
[ 1.441766] r8169 0000:03:00.1 enp3s0f1: renamed from eth0
[ 1.442393] scsi host1: ahci
[ 1.442578] scsi host2: ahci
[ 1.442662] ata1: SATA max UDMA/133 abar m2048@0xa452e000 port 0xa452e100 irq 124
[ 1.442663] ata2: DUMMY
[ 1.442665] ata3: SATA max UDMA/133 abar m2048@0xa452e000 port 0xa452e200 irq 124
[ 1.539686] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 418.56 Fri Mar 15 12:59:26 CDT 2019
[ 1.569633] checking generic (b0000000 7f0000) vs hw (b0000000 10000000)
[ 1.569635] fb0: switching to inteldrmfb from VESA VGA
[ 1.569660] Console: switching to colour dummy device 80x25
[ 1.569728] [drm] Replacing VGA console driver
[ 1.570275] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 418.56 Fri Mar 15 12:32:40 CDT 2019
[ 1.571067] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.571067] [drm] Driver supports precise vblank timestamp query.
[ 1.571778] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 1.571779] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[ 1.572280] input: SYNA7DB5:01 06CB:7DB7 Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-SYNA7DB5:01/0018:06CB:7DB7.0001/input/input5
[ 1.572414] input: SYNA7DB5:01 06CB:7DB7 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-SYNA7DB5:01/0018:06CB:7DB7.0001/input/input6
[ 1.572501] [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[ 1.572504] hid-generic 0018:06CB:7DB7.0001: input,hidraw0: I2C HID v1.00 Mouse [SYNA7DB5:01 06CB:7DB7] on i2c-SYNA7DB5:01
[ 1.590633] [drm] Initialized i915 1.6.0 20181204 for 0000:00:02.0 on minor 0
[ 1.591194] [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[ 1.591205] ACPI: Video Device [PEGP] (multi-head: yes rom: yes post: no)
[ 1.591367] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input8
[ 1.592802] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 1.592936] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input9
[ 1.594509] fbcon: inteldrmfb (fb0) is primary device
[ 1.594540] Console: switching to colour frame buffer device 240x67
[ 1.594558] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 1.596071] usb 1-5: new low-speed USB device number 2 using xhci_hcd
[ 1.752322] usb 1-5: New USB device found, idVendor=258a, idProduct=1006, bcdDevice= 1.00
[ 1.752323] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.752323] usb 1-5: Product: USB KEYBOARD
[ 1.752324] usb 1-5: Manufacturer: SINO WEALTH
[ 1.754853] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.754868] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.756481] ata1.00: ATA-9: HFS256G39TND-N210A, 30001P10, max UDMA/133
[ 1.756482] ata1.00: 500118192 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 1.756878] ata1.00: configured for UDMA/133
[ 1.759481] input: SINO WEALTH USB KEYBOARD as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/0003:258A:1006.0002/input/input10
[ 1.766965] ahci 0000:00:17.0: port does not support device sleep
[ 1.767170] scsi 0:0:0:0: Direct-Access ATA HFS256G39TND-N21 1P10 PQ: 0 ANSI: 5
[ 1.767388] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.767461] sd 0:0:0:0: [sda] 500118192 512-byte logical blocks: (256 GB/238 GiB)
[ 1.767462] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1.767469] sd 0:0:0:0: [sda] Write Protect is off
[ 1.767470] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.767481] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.768810] sda: sda1
[ 1.769494] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.816605] hid-generic 0003:258A:1006.0002: input,hidraw1: USB HID v1.10 Keyboard [SINO WEALTH USB KEYBOARD] on usb-0000:00:14.0-5/input0
[ 1.824145] input: SINO WEALTH USB KEYBOARD System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.1/0003:258A:1006.0003/input/input11
[ 1.835316] ata3.00: ATA-10: ST2000LX001-1RG174, SDM1, max UDMA/133
[ 1.835317] ata3.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.880358] usb 1-6: new full-speed USB device number 3 using xhci_hcd
[ 1.884509] input: SINO WEALTH USB KEYBOARD Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.1/0003:258A:1006.0003/input/input12
[ 1.884638] input: SINO WEALTH USB KEYBOARD Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.1/0003:258A:1006.0003/input/input14
[ 1.885014] hid-generic 0003:258A:1006.0003: input,hiddev0,hidraw2: USB HID v1.10 Keyboard [SINO WEALTH USB KEYBOARD] on usb-0000:00:14.0-5/input1
[ 1.885029] usbcore: registered new interface driver usbhid
[ 1.885030] usbhid: USB HID core driver
[ 1.923117] ata3.00: configured for UDMA/133
[ 1.932694] scsi 2:0:0:0: Direct-Access ATA ST2000LX001-1RG1 SDM1 PQ: 0 ANSI: 5
[ 1.933028] sd 2:0:0:0: Attached scsi generic sg1 type 0
[ 1.933184] sd 2:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 1.933185] sd 2:0:0:0: [sdb] 4096-byte physical blocks
[ 1.933193] sd 2:0:0:0: [sdb] Write Protect is off
[ 1.933194] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 1.933207] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.934183] sdb: sdb1 sdb2 < sdb5 >
[ 1.934451] sd 2:0:0:0: [sdb] Attached SCSI disk
[ 2.033174] usb 1-6: New USB device found, idVendor=1038, idProduct=1720, bcdDevice= 1.21
[ 2.033176] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.033177] usb 1-6: Product: SteelSeries Rival 310 eSports Mouse
[ 2.033178] usb 1-6: Manufacturer: SteelSeries
[ 2.033179] usb 1-6: SerialNumber: 000000000000
[ 2.035618] hid-generic 0003:1038:1720.0004: hiddev1,hidraw3: USB HID v1.11 Device [SteelSeries SteelSeries Rival 310 eSports Mouse] on usb-0000:00:14.0-6/input0
[ 2.036301] input: SteelSeries SteelSeries Rival 310 eSports Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:1038:1720.0005/input/input15
[ 2.036533] hid-generic 0003:1038:1720.0005: input,hidraw4: USB HID v1.11 Mouse [SteelSeries SteelSeries Rival 310 eSports Mouse] on usb-0000:00:14.0-6/input1
[ 2.037361] input: SteelSeries SteelSeries Rival 310 eSports Mouse Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.2/0003:1038:1720.0006/input/input16
[ 2.096585] input: SteelSeries SteelSeries Rival 310 eSports Mouse Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.2/0003:1038:1720.0006/input/input17
[ 2.096814] hid-generic 0003:1038:1720.0006: input,hidraw5: USB HID v1.11 Keyboard [SteelSeries SteelSeries Rival 310 eSports Mouse] on usb-0000:00:14.0-6/input2
[ 2.224343] usb 1-7: new full-speed USB device number 4 using xhci_hcd
[ 2.373842] usb 1-7: New USB device found, idVendor=04ca, idProduct=3016, bcdDevice= 0.01
[ 2.373847] usb 1-7: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.504694] usb 1-9: new high-speed USB device number 5 using xhci_hcd
[ 2.671881] usb 1-9: New USB device found, idVendor=0408, idProduct=a060, bcdDevice= 0.01
[ 2.671882] usb 1-9: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 2.671883] usb 1-9: Product: HD WebCam
[ 2.671884] usb 1-9: Manufacturer: Generic
[ 2.671884] usb 1-9: SerialNumber: 200901010001
[ 3.149807] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.276832] systemd[1]: Inserted module 'autofs4'
[ 3.288060] systemd[1]: systemd 240 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.308734] systemd[1]: Detected architecture x86-64.
[ 3.313251] systemd[1]: Set hostname to <cal-Predator-G3-571>.
[ 3.401014] systemd[1]: /lib/systemd/system/spice-vdagentd.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/spice-vdagentd/spice-vdagentd.pid → /run/spice-vdagentd/spice-vdagentd.pid; please update the unit file accordingly.
[ 3.402977] systemd[1]: Listening on udev Kernel Socket.
[ 3.403020] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.403030] systemd[1]: Reached target Remote File Systems.
[ 3.403108] systemd[1]: Listening on Journal Audit Socket.
[ 3.403135] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.403173] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.411928] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 3.417459] lp: driver loaded but no devices found
[ 3.420509] ppdev: user-space parallel port driver
[ 3.460413] systemd-journald[448]: Received request to flush runtime journal from PID 1
[ 3.588078] nvidia-uvm: Loaded the UVM driver in 8 mode, major device number 235
[ 3.611014] input: Acer Wireless Radio Control as /devices/LNXSYSTM:00/10251229:00/input/input18
[ 3.657822] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20181213/nsarguments-66)
[ 3.689242] media: Linux media interface: v0.10
[ 3.691389] acer_wmi: Acer Laptop ACPI-WMI Extras
[ 3.691408] acer_wmi: Function bitmap for Communication Button: 0x801
[ 3.697035] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.747819] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 3.748646] videodev: Linux video capture interface: v2.00
[ 3.751417] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[ 3.761627] Bluetooth: Core ver 2.22
[ 3.761639] NET: Registered protocol family 31
[ 3.761640] Bluetooth: HCI device and connection manager initialized
[ 3.761642] Bluetooth: HCI socket layer initialized
[ 3.761644] Bluetooth: L2CAP socket layer initialized
[ 3.761646] Bluetooth: SCO socket layer initialized
[ 3.798394] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[ 3.798397] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 3.798398] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 3.798398] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 3.798399] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 3.798400] RAPL PMU: hw unit of domain psys 2^-14 Joules
[ 3.803246] usbcore: registered new interface driver btusb
[ 3.809744] input: Acer WMI hotkeys as /devices/virtual/input/input19
[ 3.845956] cryptd: max_cpu_qlen set to 1000
[ 3.849073] uvcvideo: Found UVC 1.00 device HD WebCam (0408:a060)
[ 3.857679] uvcvideo 1-9:1.0: Entity type for entity Extension 4 was not initialized!
[ 3.857681] uvcvideo 1-9:1.0: Entity type for entity Processing 2 was not initialized!
[ 3.857682] uvcvideo 1-9:1.0: Entity type for entity Camera 1 was not initialized!
[ 3.857741] input: HD WebCam: HD WebCam as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/input/input20
[ 3.859127] AVX2 version of gcm_enc/dec engaged.
[ 3.859128] AES CTR mode by8 optimization enabled
[ 3.893299] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[ 3.905438] usbcore: registered new interface driver uvcvideo
[ 3.905440] USB Video Class driver (1.1.1)
[ 3.916781] idma64 idma64.0: Found Intel integrated DMA 64-bit
[ 4.021526] idma64 idma64.1: Found Intel integrated DMA 64-bit
[ 4.060724] snd_hda_intel 0000:00:1f.3: Linked as a consumer to 0000:00:02.0
[ 4.060757] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 4.061483] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 4.061487] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 4.062056] input: SYNA7DB5:01 06CB:7DB7 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-SYNA7DB5:01/0018:06CB:7DB7.0001/input/input22
[ 4.063746] hid-multitouch 0018:06CB:7DB7.0001: input,hidraw0: I2C HID v1.00 Mouse [SYNA7DB5:01 06CB:7DB7] on i2c-SYNA7DB5:01
[ 4.192358] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC255: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 4.192360] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 4.192361] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 4.192362] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 4.192363] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 4.192365] snd_hda_codec_realtek hdaudioC0D0: Headset Mic=0x19
[ 4.192366] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
[ 4.227992] intel_rapl: Found RAPL domain package
[ 4.227993] intel_rapl: Found RAPL domain core
[ 4.227994] intel_rapl: Found RAPL domain uncore
[ 4.227995] intel_rapl: Found RAPL domain dram
[ 4.231280] Adding 15624188k swap on /dev/sdb1. Priority:-2 extents:1 across:15624188k FS
[ 4.321723] EXT4-fs (sdb5): mounted filesystem with ordered data mode. Opts: (null)
[ 4.345805] ath10k_pci 0000:02:00.0: qca6174 hw3.2 target 0x05030000 chip_id 0x00340aff sub 11ad:0807
[ 4.345806] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 1 dfs 0 testmode 0
[ 4.346215] ath10k_pci 0000:02:00.0: firmware ver RM.4.4.1.c2-00057-QCARMSWP-1 api 6 features wowlan,ignore-otp,no-4addr-pad,raw-mode crc32 e061250a
[ 4.354351] audit: type=1400 audit(1555694167.543:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=840 comm="apparmor_parser"
[ 4.354889] audit: type=1400 audit(1555694167.543:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=835 comm="apparmor_parser"
[ 4.354890] audit: type=1400 audit(1555694167.543:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=835 comm="apparmor_parser"
[ 4.356055] audit: type=1400 audit(1555694167.543:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=836 comm="apparmor_parser"
[ 4.356058] audit: type=1400 audit(1555694167.543:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=836 comm="apparmor_parser"
[ 4.356059] audit: type=1400 audit(1555694167.543:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=836 comm="apparmor_parser"
[ 4.356654] audit: type=1400 audit(1555694167.547:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/ippusbxd" pid=843 comm="apparmor_parser"
[ 4.356686] audit: type=1400 audit(1555694167.547:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=842 comm="apparmor_parser"
[ 4.357429] audit: type=1400 audit(1555694167.547:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/tcpdump" pid=839 comm="apparmor_parser"
[ 4.411184] ath10k_pci 0000:02:00.0: board_file api 2 bmi_id N/A crc32 4ed3569e
[ 4.481053] ath10k_pci 0000:02:00.0: unsupported HTC service id: 1536
[ 4.499085] ath10k_pci 0000:02:00.0: htt-ver 3.56 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[ 4.606916] ath: EEPROM regdomain: 0x6c
[ 4.606917] ath: EEPROM indicates we should expect a direct regpair map
[ 4.606919] ath: Country alpha2 being used: 00
[ 4.606919] ath: Regpair used: 0x6c
[ 4.647156] ath10k_pci 0000:02:00.0 wlp2s0: renamed from wlan0
[ 4.735302] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.735303] Bluetooth: BNEP filters: protocol multicast
[ 4.735305] Bluetooth: BNEP socket layer initialized
[ 4.914769] Generic PHY r8169-301:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=r8169-301:00, irq=IGNORE)
[ 4.964724] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input24
[ 5.022802] r8169 0000:03:00.1 enp3s0f1: Link is Down
[ 5.251056] ath10k_pci 0000:02:00.0: unsupported HTC service id: 1536
[ 5.273467] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input25
