Just upgraded from 19.04 to 19.10 and loving all of the paper-cut fixes so far!
I have however run into an odd issue - the workspace switcher (ctrl-alt left/right) expands to fill the width of my screen. This is when using Marco (Adaptive Compositor) at 3840 x 2160, which I used successfully in 19.04. If I switch to 1920 x 1080, the switcher appears at a more reasonable scale.
This is already in the process of being addressed. We're redesigning the
switchers quite heavily. Unfortunately, since it's more of a cosmetic
change, it might be hard to include it as part of this release (I'll let @Wimpy decide on that), but my goal is to definitely have it for the
next MATE release.
Thanks for the info @vkareh. I'm excited to see those redesigns!
Pity that I'll be working like this for a bit, but the rest of the updates are well worth it!
