I have installed Ubuntu-Mate 20.04.2 from .iso on Dell Vostro 3700
After installing "hibernate" + "ps-utils" I am able to hibernate, but my system has a boot delay for 30 sec every boot.
In boot.log I saw
Blockquote
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... Begin: Waiting for suspend/resume device ... Begin: Running /scripts/local-block ... done.
done.
Gave up waiting for suspend/resume device
done.
Begin: Will now check root file system ... fsck from util-linux 2.34
Blockquote
Every solution I found is to disable hibernate by setting resume=none
But I will use hibernate without 30 sec boot delay.
Every try will helpful
THX Frank
