Hello,
When I compare fresh installed 20.04 VS 18.04, each in virtual machine, 20.04 boot slower than 18.04. On my virtual system, 20.04 boot into 25 s while 18.04 boot into 18 s. Will 20.04 boot faster with the first point release? People with hard disk drive (not ssd) will more suffer when they upgrade to 20.04 from 18.04.
my 20.04 vm booted in 13.9 s ... see what systemd-analyze blame
tells you. I'm on spinning disk, too. how many vcpu, mem have you allocated? (I'm 2 vcpu, 4G ram)
I don't want to compare my virtual machine (vm) with yours, it's not the purpose. I compared my vm 20.04 to my vm 18.04, each fresh installed, and there is 7 seconds between them while booting. Using virtualbox, easy to reproduce.
Try @pavlos_kairis suggestion of using systemd-analyze blame
to analyze the causes on your VMs.
He is trying to help you.
I don't need help, I don't want to fix something. I just want to share a fact: 20.04 boot slower than 18.04 in virtual machine. That's the point. I use a timer to measure time, from grub to wallpaper display.
As I'm cool, here the data. All from fresh installed in virtual machine
18.04:
[email protected]:~/Bureau$ sudo systemd-analyze
[sudo] Mot de passe de utilisateur :
Startup finished in 2.464s (kernel) + 7.885s (userspace) = 10.350s
graphical.target reached after 7.875s in userspace
[email protected]:~/Bureau$ sudo systemd-analyze blame
5.987s vboxadd.service
5.659s plymouth-quit-wait.service
1.173s snapd.service
1.134s keyboard-setup.service
912ms dev-sda1.device
513ms networkd-dispatcher.service
468ms udisks2.service
465ms snapd.seeded.service
414ms ufw.service
395ms networking.service
322ms NetworkManager.service
319ms ModemManager.service
271ms NetworkManager-wait-online.service
266ms systemd-udevd.service
258ms grub-common.service
244ms loadcpufreq.service
241ms accounts-daemon.service
206ms apparmor.service
206ms avahi-daemon.service
184ms snap-pulsemixer-283.mount
183ms snap-software\x2dboutique-31.mount
180ms snap-pulsemixer-250.mount
163ms snap-ubuntu\x2dmate\x2dwelcome-430.mount
163ms lightdm.service
162ms snap-core18-1705.mount
159ms snap-core-9066.mount
157ms snap-core18-1754.mount
157ms rsyslog.service
155ms gpu-manager.service
149ms snap-ubuntu\x2dmate\x2dwelcome-539.mount
147ms upower.service
126ms snap-core-8689.mount
122ms systemd-logind.service
116ms thermald.service
115ms systemd-journal-flush.service
110ms [email protected]
109ms wpa_supplicant.service
108ms systemd-udev-trigger.service
93ms dev-loop1.device
91ms systemd-journald.service
79ms dev-loop5.device
78ms snap-software\x2dboutique-54.mount
72ms swapfile.swap
67ms speech-dispatcher.service
65ms dev-loop3.device
65ms systemd-modules-load.service
57ms dev-loop0.device
55ms dev-loop6.device
48ms polkit.service
46ms systemd-tmpfiles-setup-dev.service
44ms systemd-sysctl.service
41ms systemd-resolved.service
39ms pppd-dns.service
37ms dev-loop7.device
34ms dev-loop4.device
31ms vboxadd-service.service
31ms systemd-tmpfiles-setup.service
30ms lm-sensors.service
27ms hddtemp.service
24ms dev-loop9.device
24ms cpufrequtils.service
21ms plymouth-start.service
19ms plymouth-read-write.service
19ms sys-kernel-debug.mount
19ms dev-mqueue.mount
18ms systemd-random-seed.service
17ms dev-hugepages.mount
17ms kmod-static-nodes.service
17ms kerneloops.service
17ms systemd-remount-fs.service
14ms console-setup.service
13ms openvpn.service
11ms systemd-update-utmp.service
10ms systemd-user-sessions.service
9ms dev-loop8.device
8ms rtkit-daemon.service
8ms sys-fs-fuse-connections.mount
7ms systemd-update-utmp-runlevel.service
5ms snapd.socket
4ms setvtrgb.service
4ms sys-kernel-config.mount
2ms dev-loop2.device
[email protected]:~/Bureau$ sudo systemd-analyze critical-chainThe time after the unit is active or started is printed after the "@" character.
The time the unit takes to start is printed after the "+" character.
graphical.target @7.875s
└─multi-user.target @7.875s
└─getty.target @7.875s
└─[email protected] @7.874s
└─system-getty.slice @7.873s
└─setvtrgb.service @7.868s +4ms
└─systemd-user-sessions.service @2.186s +10ms
└─network.target @2.181s
└─NetworkManager.service @1.857s +322ms
└─dbus.service @1.725s
└─basic.target @1.701s
└─sockets.target @1.701s
└─snapd.socket @1.694s +5ms
└─sysinit.target @1.689s
└─apparmor.service @1.482s +206ms
└─local-fs.target @1.479s
└─media-sf_shared.mount @7.741s
└─local-fs-pre.target @1.468s
└─keyboard-setup.service @333ms +1.134s
└─systemd-journald.socket @325ms
└─system.slice @324ms
└─-.slice @319ms
20.04:
Startup finished in 2.036s (kernel) + 13.733s (userspace) = 15.769s
graphical.target reached after 13.716s in userspace
12.098s vboxadd.service
11.529s plymouth-quit-wait.service
2.453s dev-sda1.device
1.563s dev-loop2.device
1.514s dev-loop0.device
1.501s dev-loop1.device
1.490s dev-loop7.device
1.473s dev-loop3.device
1.431s dev-loop5.device
1.359s dev-loop4.device
1.311s dev-loop6.device
1.131s blueman-mechanism.service
1.062s snapd.service
851ms systemd-resolved.service
789ms networkd-dispatcher.service
757ms udisks2.service
717ms NetworkManager-wait-online.service
579ms accounts-daemon.service
508ms systemd-journal-flush.service
496ms systemd-logind.service
432ms ModemManager.service
425ms systemd-timedated.service
403ms upower.service
383ms avahi-daemon.service
370ms NetworkManager.service
339ms systemd-journald.service
334ms polkit.service
276ms e2scrub_reap.service
268ms thermald.service
256ms wpa_supplicant.service
221ms grub-common.service
199ms gpu-manager.service
178ms lightdm.service
155ms keyboard-setup.service
151ms [email protected]
149ms snap-software\x2dboutique-54.mount
147ms snap-ubuntu\x2dmate\x2dwelcome-539.mount
138ms snap-ubuntu\x2dmate\x2dwelcome-524.mount
138ms grub-initrd-fallback.service
135ms apparmor.service
134ms systemd-udevd.service
131ms rsyslog.service
129ms lm-sensors.service
123ms snap-core-8935.mount
120ms systemd-udev-trigger.service
102ms pppd-dns.service
102ms systemd-modules-load.service
98ms snap-core-9066.mount
97ms networking.service
97ms snap-core18-1705.mount
95ms snap-core18-1754.mount
92ms snap-software\x2dboutique-39.mount
78ms swapfile.swap
58ms snapd.apparmor.service
50ms vboxadd-service.service
40ms systemd-sysusers.service
37ms kerneloops.service
36ms systemd-tmpfiles-setup.service
33ms systemd-random-seed.service
32ms hddtemp.service
28ms plymouth-start.service
26ms systemd-remount-fs.service
24ms ufw.service
22ms systemd-sysctl.service
22ms openvpn.service
19ms systemd-user-sessions.service
19ms dev-hugepages.mount
18ms systemd-tmpfiles-setup-dev.service
17ms dev-mqueue.mount
16ms sys-kernel-debug.mount
15ms plymouth-read-write.service
15ms sys-kernel-tracing.mount
15ms sys-kernel-config.mount
14ms kmod-static-nodes.service
14ms [email protected]
13ms systemd-update-utmp-runlevel.service
11ms rtkit-daemon.service
9ms ifupdown-pre.service
9ms console-setup.service
9ms systemd-update-utmp.service
5ms setvtrgb.service
4ms sys-fs-fuse-connections.mount
1ms snapd.socket
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target @13.716s
└─multi-user.target @13.716s
└─getty.target @13.716s
└─[email protected] @13.716s
└─system-getty.slice @13.714s
└─setvtrgb.service @13.708s +5ms
└─systemd-user-sessions.service @2.140s +19ms
└─network.target @2.132s
└─systemd-resolved.service @1.280s +851ms
└─systemd-tmpfiles-setup.service @1.240s +36ms
└─systemd-journal-flush.service @731ms +508ms
└─systemd-journald.service @389ms +339ms
└─systemd-journald.socket @382ms
└─system.slice @377ms
└─-.slice @377ms
When version 20.04.1 will be released, will it be as fast to start as 18.04 or slower as currently?
Hello Phillipe
To my non-expert eye the "dev-loop" events seem to be making a difference between 18.04 and 20.04. The "dev-loop" events are snap packages starting up, as far as I know.
That being the case, I would not expect to see much difference between 20.04 and 20.04.1, as more of Ubuntu-Mate is now being delivered as snaps I believe (I may be wrong there).
