The more I try to use 20.04 the more sure I become that it is indeed inferior to 16.04.
I installed Mate 20.04 on an "Atomic Pi" a small IOT class machine, with all upgrades. Got it running OpenVINO and Coral TPU AI code, thought maybe it has been updated enough to be OK now. Then I tried to restart it.
Hangs on reboot or shutdown. Either from the menus or with sudo shutdown -r now.
Turning off splash and quiet in the grub boot options shows its in a watchdog crash loop after reaching the shutdown or reboot target.
I've tried the various grub boot options suggested via Google for older variations and none work.
I know it not a hardware issue because if I boot an SD card with Ubuntu-Mate 16.04 no issues on shutdown or reboot.
Hardware is an Intel Atom Z8350.
