Hi erveryone, i'm really happy to have joined the Ubuntu Mate community. I've been a Mate user since ver. 16.04 and i'm very impressed about the useability and I do all my work with this OS. Now, I use ver. 20.04 and I have some (new) issues and questions.
I use the Sayonara music player and when I start the program don't show the right icon on right upper top bar (Picture 1).
In the deafult application settings, I can not change the player to Syonara, the entry just doesn't exist. I think, thats the reason that I can't use my media keys on the keyboard (forward title, start/stop, backward title) (Picture 2). The Keyboard shortcuts are set up already.
This leads me directly to the next problem. I also can not change the default E- Mail Client (it's greyed out) and I also can't start it with my keybaord shortcut (Picture 3).
it's the default Evolution installation that comes with Mate 20.04 and it is running and working. It brings also a notification when a new mail arrived.
As I wrote, the shortcuts setting are done.
Tried xinput but it doesn't show output for the special keys. Tried out with showkey it gave the followed:
0xe0 0x10
0xe0 0x90 for backward key
0xe0 0x22
0xe0 0xa2 for start/stop key
0xe0 0x19
0xe0 0x99 forward key
It's a Cherry DW5100 Keyboard, thats worked fine in 18.04.
I would add this line inside /usr/share/applications/defaults.list if not existing :
text/calendar=org.gnome.Evolution.desktop
How did you installed Syonara ? deb ? repo ?
As your icon looks broken and if you installed from .deb maybe you need to install some missing software :
Yes, logout / login and a couple of reboots. I will do a new 20.04 install. It's not a big deal for me and then check again mail settings, shortcuts and a new install of Sayonara.
Perfect
Something got wrong ...
Once you start having issues with a fresh install config, a rebuild is a good option
Thanks for the update and good luck
