OS: Ubuntu MATE 20.04.1 arm64
Target: Raspberry Pi Compute Module 4 (CM4001008, also tried CM4102016)
Carrier: CM4IO Board
Here are the steps I followed:
- Download
ubuntu-mate-20.04.1-desktop-arm64+raspi.img.xzand verify checksum. - Disable eMMC boot on CM4IO board with a jumper on J2.
- Connect
J11 USB slaveto Xubuntu 18.04 host. - Use
usbbootlatest master branch (commit:9324fd7), and mount the eMMC on the host. - Flash the image using
BalenaEtcher (AppImage) v1.5.108, also triedRaspberry Pi Imager (snap) v1.6.1. - Add
dtoverlay=dwc2,dr_mode=hoston partition:system-boot, file:usercfg.txt. (Also tried/boot/firmware/config.txtbut the USB was not enabled). - Connect ethernet. (Also tried without ethernet).
- Boot CM4 and complete the MATE installation forms.
Then:
- Installer:
Configuring system locales...(takes about 5min) - Installer:
Configuring keyboard... - Pop-up appears with title:
Installer crashed (on Ubuntu). - After submitting the report, a firefox window opens but it just hangs.
After rebooting:
- If there was ethernet connection, the installation restarts
- If there was no ethernet connection, the login screen appears but the user I filled in the form was not created, so the system is unusable.
I need to run a non-standard resolution display over HDMI, and MATE was the only available OS for CM4 I found that supports it. Any workarounds or other OS recommendations are welcome!
