Gents, et al:
Continuing to have issues with my U-MATE 20.10 install . . . today it probably literally took 5 minutes from click power button to reach GUI log in window . . . think I've posted here about this previously . . . the log in "tray" loads in the green GUI window to upper left corner . . . asking for a TTY-like "user name" and then "password" . . . rather than just password . . . .
Once logged in things behave more or less normally speed wise . . . . But, I ran an "apt" which showed 27 packages, when I came back the system had "logged out" of the GUI?? I logged back in and the console window was gone?
I continued to use the browser and while I was doing that it sounded like the cpu was spinning up faster and faster?? I didn't check htop or anything to see what was going on . . . I clicked "shut down" to try to get to "restart" . . . I clicked restart and an error on "api . . . xxxx is still running do you want to reboot anyway?" I clicked yes . . . took another minute and the system logged out and stayed with the log in window for maybe a minute . . . then it restarted??
Seems like there is an issue . . . didn't seem like anyone else is having the problem . . . after the 5 minute boot to log in time I filed another bug report.
