Simple question probably very difficult to answer. I have a 240Hz monitor but can only set it to 120Hz. Is there a way to set 240Hz.
Thanks in Advance Zeb...
ps used yesterdays Mate daily ISO for my install and then used the Rolling-rhino script. Cos why not live on the edge
