2d drafting / cad on SBC
i am planning to swith fron windows office network to a client server system.
Server is configured as : free NAS / OMV planned
AMD A10 - 6800K
RAM 4 GB
HDD 2TB
ASUS MoBo
Clients shall be SBC like rasberry PI 3B/ Banana PI M3/ Odroid C2/ Odroid XU4
General work load - E-mail / Ms-office, some work stations may also be using 2D drawing / drafting (CAD)
my query:
  1. how do i operate my current cad software (draft sight) on the SBC,
  2. which OS is recommended
  3. which office software is recommended
    4)how to bind mac address & ID Password so that no one changes the seat and fetch data .
  4. any other thing you feel is important.
Thanks in advance
Hi @abk,
I’m not sure about networking but according to their website, Draftsight runs on Ubuntu 14.04 (Download from https://ubuntu-mate.org/trusty/ ).
For Raspi 3 there is a link for the download Ubuntu Mate version) but Draftsight doesn’t seem to have a version for that!:
Libreoffice is installed by default so just run the following terminal command (Ctrl + Alt + t) to install the full meta package:
sudo apt-get install libreoffice
I hope that at least answers questions 1, 2 and 3 for you!. :smiley:
Your other thread has been closed as it is a duplicate!:
https://ubuntu-mate.community/t/2d-drafting-drawing-cad-on-sbc/10352
Hi Wolfman,
Thanks a tone for your research and detailed input.
further i would like to enquire that will ubuntu 14.04 function on any of this SBC and how will i load that cad software?
HI @abk,
sorry but I cannot answer your question as I have never used SBC, maybe @lah7 or @Wimpy can help you there, or indeed one of the other Forum members?. :smiley:
As far as the CAD software goes; I cannot find a link for Raspi so you might be out of luck and have to stick to a normal PC install or try this: http://www.freecadweb.org/wiki/index.php?title=Download , maybe someone else knows different?. :smiley:
READ THE WARNING!:
FreeCAD is under heavy development and might not be ready for production use
I don't get it, Binding and bonding is for routers and you are talking about your NAS right?
That warning and heavy development is showing since like abut half and a year :fearful:
For the server??? You are on Ubuntu Mate's forum :point_up:
Hi @malwaredpc,
I thought it a god idea to post the warning, there is a stable PPA though!:
https://launchpad.net/~freecad-maintainers
I didn’t know there was a ppa! :slight_smile:
@abk please, consider doing a test on which software is good for your purposes. If it turns out that the software doesn’t do what you need, you will be cursing a lot of time. For example, FreeCAD has a Windows version too (if you are on that platform). And there is a LbreCAD and probably more software, probably the so called commercial, you can test first.
