Does it work with Window List or MATE Dock? If it doesn’t, then this is better off advocated in the vanilla Ubuntu forums until there is some proof of concept to make it work with more things than the Unity launcher.
i dont test it but the applet can be teak to work. we have the mate tweak that does all the think. we just need to implemate more options in it and bridge with a applet.
Well, don’t say it can be done, do it. You don’t need MATE Tweak for your idea to work, because MATE Tweak just does scripted actions for things that already exist; It’s nothing special, far as an application.
MATE Tweak does make it easier; You can provide dependent software we can install, and pair that with a panel profile (when you save one, a notification tells you where it is saved at) so other users can check it out.
First of all it was a idee. Not a request etc soo chill down with this type
of comments.
Second. If i know how to code i do so much more then posting here and doing
bug reports.
Soo yea it was just a ideea to bring some new features to the os.
