It is known that modern Ubuntu MATE 20.10 is capable to boot from USB.
If you want to upgrade 20.10 to 21.04 by sudo do-release-upgrade or update-manager -c , the resulting system will be able to boot from USB too. This is true for both 32-bit (armhf) and 64-bit (arm64).
But what is about Ubuntu MATE 20.04 LTS?
The below guide shows how to boot existing Ubuntu MATE 20.04.1 LTS from USB.
Using 32-bit armhf image
What should we do:
Install updated bootloader into RPi, see this guide for complete instruction.
Download official installation image to laptop using link https://ubuntu-mate.org/download/armhf/focal/ and write it directly to USB flash or USB SSD.
Mount
system-bootpartition on laptop and then replace the contents ofconfig.txtfile with the following lines from 20.10 image:[pi4] max_framebuffers=2 [all] kernel=vmlinuz cmdline=cmdline.txt initramfs initrd.img followkernel # Enable the audio output, I2C and SPI interfaces on the GPIO header dtparam=audio=on dtparam=i2c_arm=on dtparam=spi=on # Enable the FKMS ("Fake" KMS) graphics overlay, enable the camera firmware # and allocate 128Mb to the GPU memory dtoverlay=vc4-fkms-v3d gpu_mem=128 start_x=1 # Comment out the following line if the edges of the desktop appear outside # the edges of your display disable_overscan=1 # If you have issues with audio, you may try uncommenting the following line # which forces the HDMI output into HDMI mode instead of DVI (which doesn't # support audio output) #hdmi_drive=2 # If you have a CM4, uncomment the following line to enable the USB2 outputs # on the IO board (assuming your CM4 is plugged into such a board) #dtoverlay=dwc2,dr_mode=hostthen unmount this
system-bootpartition and detach its USB storage device. -
Insert USB storage device into RPi 4, power it, wait for first boot and enjoy!
Using 64-bit arm64 image
What should we do:
Download official installation image to laptop using link https://ubuntu-mate.org/download/arm64/focal/ and write it to microSD card using USB- or internal cardreader.
Boot Raspberry Pi 4 using microSD card as usual: choose locale, create user, reboot, login to system, then install all updates and do cleanup by
sudo apt update && sudo apt dist-upgrade -y && sudo apt autopurge -y && sudo apt clean -y, reboot to ensure that system on microSD is fully functional, poweroff the Raspberry Pi 4. -
Connect microSD card to laptop, mount
system-booton laptop and then replace the contents ofconfig.txtfile with the following lines:[pi4] max_framebuffers=2 [all] arm_64bit=1 # kernel=uboot_rpi_4.bin kernel=vmlinuz cmdline=cmdline.txt initramfs initrd.img followkernel # device_tree_address=0x03000000 # enable_uart=0 # Enable the audio output, I2C and SPI interfaces on the GPIO header dtparam=audio=on dtparam=i2c_arm=on dtparam=spi=on # Enable the FKMS ("Fake" KMS) graphics overlay, enable the camera firmware # and allocate 128Mb to the GPU memory dtoverlay=vc4-fkms-v3d gpu_mem=128 start_x=1 # Comment out the following line if the edges of the desktop appear outside # the edges of your display disable_overscan=1 # If you have issues with audio, you may try uncommenting the following line # which forces the HDMI output into HDMI mode instead of DVI (which doesn't # support audio output) #hdmi_drive=2 # If you have a CM4, uncomment the following line to enable the USB2 outputs # on the IO board (assuming your CM4 is plugged into such a board) #dtoverlay=dwc2,dr_mode=host -
Insert microSD card to USB-cardreader, connect USB-cardreader to Raspberry Pi 4, allow it to boot, then power it off.
Copy the whole microSD card to USB-flash or USB SSD, optionally grow the size of
writablepartition to fit free space of USB media. -
Connect USB media to Raspberry Pi 4, boot it and enjoy!
