I tried again by removing and reinstalling without success. There were errors I see in terminal.
john46@ubuntu:~$ sudo apt-get install ttf-mscorefonts-installer
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following additional packages will be installed:
cabextract
The following NEW packages will be installed:
cabextract ttf-mscorefonts-installer
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 21.8 kB/47.1 kB of archives.
After this operation, 168 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://us.archive.ubuntu.com/ubuntu cosmic/universe amd64 cabextract amd64 1.6-1.1 [21.8 kB]
Fetched 21.8 kB in 0s (119 kB/s)
Preconfiguring packages …
Selecting previously unselected package cabextract.
(Reading database … 193505 files and directories currently installed.)
Preparing to unpack …/cabextract_1.6-1.1_amd64.deb …
Unpacking cabextract (1.6-1.1) …
Selecting previously unselected package ttf-mscorefonts-installer.
Preparing to unpack …/ttf-mscorefonts-installer_3.7ubuntu4~really3.6ubuntu3_all.deb …
mscorefonts-eula license has already been accepted
Unpacking ttf-mscorefonts-installer (3.7ubuntu4~really3.6ubuntu3) …
Processing triggers for update-notifier-common (3.192.7) …
ttf-mscorefonts-installer: processing…
ttf-mscorefonts-installer: downloading http://downloads.sourceforge.net/corefonts/andale32.exe
Err:1 http://downloads.sourceforge.net/corefonts/andale32.exe
Redirection from https to ‘http://downloads.sourceforge.net/mirrorproblem?failedmirror=cfhcable.dl.sourceforge.net’ is forbidden [IP: 146.71.73.6 443]
E: Failed to fetch https://cfhcable.dl.sourceforge.net/project/corefonts/the fonts/final/andale32.exe Redirection from https to ‘http://downloads.sourceforge.net/mirrorproblem?failedmirror=cfhcable.dl.sourceforge.net’ is forbidden [IP: 146.71.73.6 443]
E: Download Failed
Setting up cabextract (1.6-1.1) …
Processing triggers for man-db (2.8.4-2) …
Setting up ttf-mscorefonts-installer (3.7ubuntu4~really3.6ubuntu3) …
Processing triggers for fontconfig (2.13.0-5ubuntu3) …
john46@ubuntu:~$
