Adjusting Screen to Full Overscan
Hi
With my install of Ubuntu Mate, it has set the screen display so that it has a black box around it.
When I installed Raspbian Jesse before, I needed to change a setting to make the program ‘overscan’.
I assume the same thing applies here.
Would you be able to advise me on how to change Ubuntu Mate to overscan to a 1920 x1080 (16:9)?
Kind Regards
Ian
Hi @sarian90,
does this help?:
https://www.raspberrypi.org/forums/viewtopic.php?p=305797&sid=4fe5fc284854fe3723841f79ea2c6546#p305797
http://elinux.org/RPiconfig#Video_mode_options
Edit the /boot/config.txt file and disable (or tweak) the overscan settings.
For my HD screen I just needed DISABLE_OVERSCAN=1
