I have a real problem with suspend/resume not returning my pc into a workable state: My keyboard and mouse are not working anymore . Which is pretty 'sh i tty' as the only option is to use a forced power off.
Of course I tried some stuff myself, but after a week of troubleshooting I'm out of idea's.
I did manage a cumbersome workaround, it enables usb wakeup for mouse/keyboard, but that only lasts for 2+ of hours. After that, its a hard lockout.
I can remove keyboard and mouse, plug them into another USB-port and with some luck use them again. Plug them back in the original port and they are disabled again.
How can we get these basics working ?
olek
11 June 2020 16:18
2
Hi
Can you share with us some dmesg after such input outage ?
Sure have a log ready, but how do I attach it ?
[ 73.617947] PM: dpm_run_callback(): usb_dev_resume+0x0/0x20 returns -22
[ 73.617966] PM: Device 3-2 failed to resume async: error -22
[ 73.873891] PM: dpm_run_callback(): usb_dev_resume+0x0/0x20 returns -22
[ 73.873919] PM: Device 3-1 failed to resume async: error -22
[ 73.874509] fbcon: Taking over console
[ 73.874584] OOM killer enabled.
[ 73.874586] Restarting tasks ...
[ 73.874667] usb 3-1: USB disconnect, device number 2
[ 73.874673] usb 3-1.1: USB disconnect, device number 3
[ 73.878812] Console: switching to colour frame buffer device 240x67
[ 73.893780] done.
[ 73.893875] PM: suspend exit
[ 73.933954] radeon_dp_aux_transfer_native: 242 callbacks suppressed
[ 74.107423] usb 3-2: USB disconnect, device number 4
[ 74.114221] Generic FE-GE Realtek PHY r8169-100:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-100:00, irq=IGNORE)
[ 74.225788] r8169 0000:01:00.0 enp1s0: Link is Down
You can clearly see those USB disconnects
olek
11 June 2020 18:55
4
Guy, please try this fix :
keyboard, suspend
Hi olek,
atkbd.reset did not work.
usbcore.autosuspend=-1, did not work either.
PM fails to resume and then disconnects those ports.
Its getting late, I found this one. Will try tomorrow:
Here's an idea: How about a simple app that allows you to install fixes from the forum ?
Anyway, after some hours of $!%!£$"$£"%!%% I scripted a workaround: (because I'm awesome, but don't tell anyone)
It searches all usb device's for a keyboard or mouse string, then enables them for wakeup.
Create both files below, then:
systemctl enable suspendfix.service
systemctl start suspendfix.service
/etc/systemd/system/suspendfix.service
[Unit]
Description=enables mouse & keyboard after suspend/resume cycle
[Service]
Type=oneshot
ExecStart=/etc/init.d/suspendfix.sh start
ExecStop=/etc/init.d/suspendfix.sh stop
RemainAfterExit=yes
[Install]
WantedBy=multi-user.target
#!/bin/bash
# workaround: enables mouse & keyboard after suspend/resume cycle
wakeup_mouse_keyb(){
OLDIFS=$IFS;IFS=$'\n'
PRODUCTLIST=$(grep -i 'mouse\|keyboard' /sys/bus/usb/devices/*/product)
for p in $PRODUCTLIST;do
devicename=${p#/*product:}
product="${p%/product*}/product"
wakeup="${p%/product*}/power/wakeup"
echo "$1" 2>/dev/null > $wakeup
printf "$devicename : $(cat $wakeup)\n"
done
IFS=$OLDIFS
case "$1" in
start)
wakeup_mouse_keyb enabled
stop)
wakeup_mouse_keyb disabled
restart)
$0 stop
sleep 1
$0 start
esac
olek
17 June 2020 16:58
7
Congrats Nice workaround
Thanks to you others with similar HW / issue will be able to get back their devices after sleep.
Thanks @Guy
You can also try to upgrade your kernel to latest - this solved many issues i got with my setups
Someone else talked about this on itfoss.com forum. their solution was as follows;
sudo apt-get install --reinstall xserver-xorg-input-all
This was from a posting about 14.04, however it worked for me on 22.04 lts.
Hi, @■■■■_Stephens and welcome to the Ubuntu MATE Community
You wrote:
■■■■_Stephens:
Thanks for the tip! For other people seeing this topic, I believe ■■■■_Stephens is referring to the following article in the itsfoss.com web site:
