Hi!
After upgrade from 18.04-2 to 19.04 yesterday, the power manager daemon don't start.
Where to find the service files?
I can't find them...
Hi!
Your question is a bit unclear.
Which power manager do you mean - upowerd or mate-power-manager?
For upower you have to check its state with systemctl status upower.service.
On my clean 19.04 VM I have the following:
$ systemctl status upower.service
● upower.service - Daemon for power management
Loaded: loaded (/lib/systemd/system/upower.service; disabled; vendor preset: enabled)
Active: active (running) since Sat 2019-07-20 22:51:06 MSK; 6min ago
Docs: man:upowerd(8)
Main PID: 958 (upowerd)
Tasks: 3 (limit: 1097)
Memory: 2.3M
CGroup: /system.slice/upower.service
└─958 /usr/lib/upower/upowerd
июл 20 22:51:06 disco systemd[1]: Starting Daemon for power management...
июл 20 22:51:06 disco systemd[1]: Started Daemon for power management.
The MATE Power Manager is usually started by graphical desktop from /etc/xdg/autostart/mate-power-manager.desktop file.
To be honest I'll recommend to reinstall Ubuntu MATE 18.04 LTS system. This will give stable result and about 5 painless years
Thanks for the Info
Power-Manager is now running again.
(SOLVED)
