If I remember correctly it is now set to pipewire by default and you will have to set it back to pulse audio or alsa output. You might have to edit your script back to the original file. Mine plays fine on either pulse or alsa, but not on pipewire.
did a new test - new config @ ".soundrc" @ home folder:
pcm.!default {
type plug
slave.pcm "dmixer"
ctl.equal {
type equal;
pcm.plugequal {
type equal
slave.pcm "plug:dmixer"
ctl.!default {
type hw
card 0
pcm.dmixer {
type dmix
ipc_key 5678293
slave {
pcm {
type hw
card 0
device 0
ctl.mixer0 {
type hw
card 0
syslog:
[25858.246261] usb 10-2: 1:0: usb_set_interface failed (-71)
[25858.246651] usb 10-2: uac_clock_source_is_valid(): cannot get clock validity for id 40
[25858.246654] usb 10-2: clock source 40 is not valid, cannot use
[25858.247010] usb 10-2: 1:1: cannot get freq (v2/v3): err -71
[25858.247374] usb 10-2: 1:1: cannot set freq 48000 (v2/v3): err -71
[25858.250156] usb 10-2: 1:0: usb_set_interface failed (-71)
[25858.253543] usb 10-2: 1:0: usb_set_interface failed (-71)
[25858.253927] usb 10-2: uac_clock_source_is_valid(): cannot get clock validity for id 40
[25858.253931] usb 10-2: clock source 40 is not valid, cannot use
[25858.254290] usb 10-2: 1:1: cannot get freq (v2/v3): err -71
[25858.254654] usb 10-2: 1:1: cannot set freq 48000 (v2/v3): err -71
[25858.257396] usb 10-2: 1:0: usb_set_interface failed (-71)
[25858.260702] usb 10-2: 1:0: usb_set_interface failed (-71)
[25858.261069] usb 10-2: uac_clock_source_is_valid(): cannot get clock validity for id 40
[25858.261072] usb 10-2: clock source 40 is not valid, cannot use
[25858.261447] usb 10-2: 1:1: cannot get freq (v2/v3): err -71
[25858.261818] usb 10-2: 1:1: cannot set freq 48000 (v2/v3): err -71
[25858.264578] usb 10-2: 1:0: usb_set_interface failed (-71)
[27365.049342] usb 10-2: new high-speed USB device number 15 using xhci_hcd
[27365.197758] usb 10-2: New USB device found, idVendor=17cc, idProduct=1011, bcdDevice= 0.32
[27365.197764] usb 10-2: New USB device strings: Mfr=12, Product=7, SerialNumber=13
[27365.197767] usb 10-2: Product: Traktor Audio 6
[27365.197769] usb 10-2: Manufacturer: Native Instruments
[27365.197770] usb 10-2: SerialNumber: 427A3B0A
mtp-probe: checking bus 10, device 15: "/sys/devices/pci0000:00/0000:00:06.0/0000:03:00.0/usb10/10-2"
mtp-probe: bus: 10, device: 15 was not an MTP device
systemd[2104]: Reached target Sound Card.
systemd[1]: Condition check resulted in Manage Sound Card State (restore and store) being skipped.
systemd[1]: Reached target Sound Card.
systemd[2647]: Reached target Sound Card.
meth mtp-probe: bus: 10, device: 15 was not an MTP device
Strange, no idea, I don't know what the problem could be.
