Alternative for adobe flash player
Is there any light weight alternative for adobe flash plugin for ubuntu.
whenever I enables it, my system suffers lag.
Can I use HTML5 for those sites ?:sob:
Whether or not you can use HTML5 depends on the website. Some do support it (like youtube), some do not (yet), but as Flash is increasingly being considered deprecated (even by Adobe), it should be phased out eventually.
You could try installing the browser-plugin-gnash package instead. I am not sure how fast and compatible, it is, though.
I would simply avoid any websites that require Flash. It is extremely insecure.
