I miss multiple days forecasts with the built in weather applet, like the Xfce and Linux Mint weather applets have.
Can alternative weather applets be installed? If so, which ones and from where/how?
You can use My-Weather-Indicator from Atareo.
To install it use commands below:
sudo add-apt-repository ppa:atareao/atareao
sudo apt-get update
sudo apt-get install my-weather-indicator
It is very feature rich. I use it along with pre-installed weather in Clock applet.
