I just noticed a bit of an oddity in the scrollbar colors of the Ambiant MATE Dark theme compared to its lighter counterpart:
From left to right:
Ambiant MATE
how I expected Ambiant MATE Dark to look
how Ambiant MATE Dark actually looks (a bit too dark, and it loses the MATE accent color)
Hello
This seems to be common with all themes. I am currently on GreenLaguna and thought I give a try on it for a custom scrollbar. So I have created a custom theme package and hit on my first problem. I have yet to be able to add my custom theme to the appearance gui. I have put it in ~/.themes and /usr/share/themes. Both ways should work, I have used this in the past in Ubuntu.
For the moment I’m stuck until I get pass this.
Any thoughts?
@Alif_Dal_Mim because you asked about scrollbar color.
@lah7 could this be a bug?
I still have the above problem, but made some headway with scrollbar background color.
Added this to ~/.config/gtk-3.0/gtk.css
scrollbar trough {
background-color: shade(@theme_bg_color, 0.10);
background-image: none;
border-style: solid;
border-color: alpha(@frame_color, 0.6);
This gives me black scrollbar background. Still more tweaking to do, but a start in the right direction.
I’m getting my ideas from here:
https://developer.gnome.org/gtk3/stable/theming.html
This looks like the next needed part:
scrollbar slider,
scrollbar .slider {
border-color: transparent;
Out of play time for now. Later
lah7
13 March 2018 13:51
5
I haven’t been following the themes @m1804 but I asked the guy who has oversight.
According to @wimpy , the dark one is as intended. His thoughts were the green made it look stark.
I would personally prefer the green variant too, since it helps with accessibility with a better contrast. You could also say it stays consistent with the regular theme.
The source code for themes can be found in ubuntu,-mate-artwork , if you’d like to contribute the changes.
Final results
Note:
This tweak should work on all default themes. It was created using GreenLaguna, so milage may vary.
Scrollbar/buttons/slider tweaks will need to be added to (home directory) ~/.config/gtk-3.0/gtk.css (the /gtk.css file will need to be created at that location) and this is a per user modification that will not work system wide. Currently I cannot add a custom theme system wide using root access to /themes or user themes to /.themes. The appearance GUI just will not see them.
Code to paste to /gtk.css:
scrollbar slider {
/* Size of the slider */
min-width: 15px;
min-height: 15px;
border-radius: 17px;
/* Padding around the slider */
border: 2px solid transparent;
scrollbar trough {
background-color: shade(@theme_bg_color, 0.60);
scrollbar button,
scrollbar button.vertical,
scrollbar button.horizontal,
scrollbar .button,
scrollbar .button.vertical,
scrollbar .button.horizontal {
background-color: shade(@theme_bg_color, 0.4);
scrollbar.vertical slider,
scrollbar.vertical .slider {
background-image: linear-gradient(to top,
shade(@toolbar_gradient_base, 0.85),
white);
scrollbar.horizontal slider,
scrollbar.horizontal .slider {
background-image: linear-gradient(to left,
white);
@lah7
Lets see what people think of this first and I will also post here:
Mate default theme has the scrollbar set pretty nice, but I still like to tweak it a bit. This is something I don't want to do everytime I switch themes. So here's a way to tweak the scrollbar that will work for all the gtk3 themes.
NOTE: This will change most, but not all windows. Example: No effect on Synaptic Package Manager.
Create a new file and name it "gtk.css".
Place this file in your home folder at the location /.config/gtk-3.0/gtk.css
And place this script in your newly create…
Ok, here ya go. This is tweaked for Ambiant MATE Dark theme.
scrollbar slider {
min-width: 15px;
min-height: 15px;
scrollbar trough {
scrollbar button,
scrollbar .button,
background-image: radial-gradient(ellipse at center, #86A551 0%, #86A551 100%);
Another way to make scrollbar more visible (green) is to replace lines 162-163 in /usr/share/themes/Ambiant-MATE-Dark/gtk-3.0/gtk-main.css with
@define-color scrollbar_slider_bg_color shade(@selected_bg_color , 0.89);
@define-color scrollbar_slider_hover_bg_color shade(@selected_bg_color , 0.93);
btw similar issue has been raised in
opened 08:33AM - 07 Aug 16 UTC
closed 08:44AM - 07 Aug 16 UTC
I am using the Ambiant-MATE theme from MATE 1.14.1 (from the offical ppa) with U… buntu MATE 16.04.1. Most of the scrollbars look reasonable with this theme, except for mate-terminal, which is essentially "dark grey on dark grey", so it's very hard to see the scrollbar thumb.
From left to right: Caja, mate-terminal, Firefox
Note: I slightly customized the theme by giving it larger left/right/bottom edges, but otherwise it is stock. Those modifications do not affect the scrollbars.
I am using the Ambiant-MATE theme from MATE 1.14.1 (from the offical ppa) with Ubuntu MATE 16.04.1. Most of the scrollbars look reasonable with this theme, except for mate-terminal, which is essentially "dark grey on dark grey", so it's very hard to...
https://bugs.launchpad.net/ubuntu-mate/+bug/1377410
