So, here is what I have come up with. I am a "qualified" happy with that, but hope others have feedback on where I may have overlooked something.
Purpose/Intent:
from Live ISO terminal session, perform partitionning and formatting of a target disk BEFORE starting the installation process, to simplify the activities which the ISO install encompasses.
intended as first step of a 4-step process involving
[1] disk formatting (this script),
[2] install of Ubuntu Server,
[3] install MATE Desktop, and
[4] use another script which prompts interractively for all User-specified Applications from a list of the most used/cherished Applications available from the Ubuntu distribution repository.
The script offers an option to visually confirm the sequence that will be performed for each line entry in a "layout specification file", before committing to applying that specification to the intended target installation drive.
Everything seems to work fine but, for "partition 4", where I create the partition intended for "root", it reports
parted: invalid token: root
I don't know if that is because an actual root was already mounted, or the fact that the mountpoint path was identified as "/altroot", rather than "/".
Would I get that same error if I was running from a Live Session or not, pre-install of Ubuntu Server setup?
File: partitions_sdc_specs.conf
# partNum:partFsType:partStart:partEnd:partName:partMount:partFlag
1 linux-swap 24KB 4MiB GRUB none null
2 linux-swap 4MiB 64MiB HIBERNATE none swap
3 ext4 64MiB 256MiB BOOT /altboot boot
4 ext4 256MiB 1GiB DB008_F1 /altroot root
5 ext4 1GiB 100% DB008_F2 /DB008_F2 null
The following is a session log of the actual formatting of the drive:
ericthered @ OasisMega1 : /DB001_F4/00__18__DISTRO__Build/001__DiskPartsAndFormats
$ ./001__PreInstallDiskPartitionningAndFormatting.sh --layout "./partitions_sdc_specs.conf" --device "/dev/sdc" --apply
Verifying the specified disk is recognized and accessible ...
Ensuring that the disk has no active dependancy for swap ...
[sudo] password for ericthered:
Confirmed any active SWAP was disabled ...
Ensuring that the disk is not busy or mounted ...
Confirmed /dev/sdc is not mounted ...
Scanning '/dev/sdc' for badblocks before continuing ...
Starting Process of Partitioning and Formatting '/dev/sdc' ...
Create new GPT-type partition table ...
Extract partition data from next entry in specifications array ...
partNum = 1
partFsType = linux-swap
partStart = 24KB
partEnd = 4MiB
partName = GRUB
partMount = none
partFlag = null
Create a partition to specifications using 'parted mkpart ...' ...
Warning: The resulting partition is not properly aligned for best performance: 46s % 2048s != 0s
Update OS awareness of the disk's new structure using 'partprobe' ...
Ensure device node (udev) creation is complete ...
Format partition to specification ...
Setting up swapspace version 1, size = 4 MiB (4165632 bytes)
LABEL='GRUB', UUID=71db8ca8-2ca4-4926-925d-3c378ebe8f1d
/dev/sdc1 8:33 1 4M 0 part
Hit return to continue ...
partNum = 2
partStart = 4MiB
partEnd = 64MiB
partName = HIBERNATE
partMount = none
partFlag = swap
mkswap: /dev/sdc2: warning: wiping old swap signature.
Setting up swapspace version 1, size = 60 MiB (62910464 bytes)
LABEL='HIBERNATE', UUID=cb8c2a02-a871-46d9-b455-1095d8435c99
/dev/sdc2 8:34 1 60M 0 part
partNum = 3
partFsType = ext4
partStart = 64MiB
partEnd = 256MiB
partName = BOOT
partMount = /altboot
partFlag = boot
mke2fs 1.46.5 (30-Dec-2021)
Creating filesystem with 49152 4k blocks and 49152 inodes
Filesystem UUID: ae44c502-de89-41c7-bf9e-7b58611d40c3
Superblock backups stored on blocks:
32768
Allocating group tables: done
Writing inode tables: done
Creating journal (4096 blocks): done
Writing superblocks and filesystem accounting information: done
/dev/sdc3 8:35 1 192M 0 part /altboot
partNum = 4
partFsType = ext4
partStart = 256MiB
partEnd = 1GiB
partName = DB008_F1
partMount = /altroot
partFlag = root
Creating filesystem with 196608 4k blocks and 49152 inodes
Filesystem UUID: 2af8b0d6-3788-4dd8-95c2-e7399529091c
32768, 98304, 163840
/dev/sdc4 8:36 1 768M 0 part /altroot
partNum = 5
partFsType = ext4
partStart = 1GiB
partEnd = 100%
partName = DB008_F2
partMount = /DB008_F2
partFlag = null
Creating filesystem with 3527936 4k blocks and 883008 inodes
Filesystem UUID: d835a150-ffb7-44c7-b2ed-a8dbc0d04599
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208
Creating journal (16384 blocks): done
/dev/sdc5 8:37 1 13.5G 0 part /DB008_F2
Report final state of disk partitioning ...
Model: USB DISK 2.0 (scsi)
Disk /dev/sdc: 15.5GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 23.6kB 4194kB 4171kB linux-swap(v1) GRUB swap
2 4194kB 67.1MB 62.9MB linux-swap(v1) HIBERNATE swap
3 67.1MB 268MB 201MB ext4 BOOT boot, esp
4 268MB 1074MB 805MB ext4 DB008_F1
5 1074MB 15.5GB 14.5GB ext4 DB008_F2
/dev/sdc 14.5G block:scsi:usb:pci
/dev/sdc1 swap GRUB 71db8ca8-2ca4-4926-925d-3c378ebe8f1d 4M block:scsi:usb:pci
/dev/sdc2 swap HIBERNATE cb8c2a02-a871-46d9-b455-1095d8435c99 60M block:scsi:usb:pci
/dev/sdc3 ext4 BOOT ae44c502-de89-41c7-bf9e-7b58611d40c3 192M /altboot block:scsi:usb:pci
/dev/sdc4 ext4 DB008_F1 2af8b0d6-3788-4dd8-95c2-e7399529091c 768M /altroot block:scsi:usb:pci
/dev/sdc5 ext4 DB008_F2 d835a150-ffb7-44c7-b2ed-a8dbc0d04599 13.5G /DB008_F2 block:scsi:usb:pci
Reload the updated fstab ...
File: 001__PreInstallDiskPartitionningAndFormatting.sh
(Beta Test version of script (looking for feedback)
#!/bin/bash
# SPDX-License-Identifier: GPLv3-or-later
# SPDX-FileCopyrightText: © 2026 Eric Marceau <[email protected]>
# For the full text of the GNU General Public License version 3.0 (a.k.a. GPLv3)
# please visit: https://spdx.org/licenses/GPL-3.0-or-later.html
### Purpose/Intent:
### * from Live ISO terminal session, perform partitionning and formatting
### of a target disk **BEFORE** starting the installation process,
### to simplify the activities which the ISO install encompasses.
### * intended as first step of a 3-step process involving
### [1] disk formatting (this script),
### [2] install of Ubuntu Server,
### [3] install MATE Desktop, and
### [4] use another script which prompts interractively for all User-specified
### Applications from a list of the most used/cherished Applications
### available from the Ubuntu distribution repository.
### Version:
### March 27 2026 - Eric Marceau - v0.8 Beta Test
echo="echo -e"
testForDisk()
testRoot=$( df -h / | grep '^/' | awk '{ print $1 }' | sed 's+[0-9]*++g' )
testTarget=$( lsblk --paths | grep '^'${DISK} | awk '{ print $1 }' )
test ${doDemo} -eq 1 && ${echo} "\tDEMO: testTarget = '${testTarget}' ..."
if [ -z "${testTarget}" ]
then
${echo} "\n\t ABORT. Specified disk does not exist.\n" ; exit 1
fi
if [ "${testRoot}" = "${testTarget}" ]
then
${echo} "\n\t ABORT. Specified disk is system ROOT.\n" ; exit 1
fi
} #testForDisk()
testForSwap()
sudo swapoff ${DISK}?* 2>>/dev/null
testSwaps=$( sudo swapon | grep ${DISK} )
if [ -n "${testSwaps}" ]
then
${echo} "\n\t ABORT. Specified disk has active SWAP. Was unable to turn that off!\n" ; exit 1
else
${echo} "\tConfirmed any active SWAP was disabled ..."
fi
} #testForSwap()
unMountDisk()
sudo umount ${DISK}?* 2>>/dev/null
testMounts=$( sudo mount | grep ${DISK} )
if [ -n "${testMounts}" ]
then
${echo} "\n\t ABORT. Specified disk has active mounts. Was unable to unmount partitions!\n" ; exit 1
else
${echo} "\tConfirmed ${DISK} is not mounted ..."
fi
} #unMountDisk()
transient_PartitionSpecificationDefinition()
### IMPORTANT: NOT meant to be part of permanent script logic
${echo} "\nCapture Partition Specifications (from command-line or config file) ..."
### Guidance:
### - Hibernate target should be system's primary swap to
### minimize delay from copying from swap to hibernate image
### - Hibernate target should be 1.5 to 2 times size of RAM
### FUTURES:
### - Calculate size of HIBERNATE swap space based on installed RAM
### - Calculate start and end point of each partition based
### size specification for each partition
### - Create fstab entries using UUIDs the resulting disk layout
#cat >"${specifications}" <<EnDoFfIlE
## partNum:partFsType:partStart:partEnd:partName:partMount
#1 core 8KB 4MiB GRUB none
#2 swap 4MiB 8GiB HIBERNATE none
#3 ext4 8GiB 12GiB BOOT /boot
#4 ext4 12GiB 200GiB DB007_F1 /
#5 ext4 200GiB 100% DB007_F2 /DB007_F2
#EnDoFfIlE
#1 linux-swap 4MiB 64MiB HIBERNATE none
#2 ext4 64MiB 256MiB BOOT /altboot
#3 ext4 256MiB 1GiB DB008_F1 /altroot
#4 ext4 1GiB 100% DB008_F2 /DB008_F2
#EnDoFfIlE
EnDoFfIlE
if [ ! -s "${specifications}" ]
then
${echo} "\tABORT - unable to create '${specifications}' for demo run.\n" >&2 ; exit 1
fi
} #transient_PartitionSpecificationDefinition()
demoSetup()
### Call function to create sample partitioning specification
### Create file that will behave as device
devFile="/site/DB007_F1/tmp/demo.img"
locn="$(dirname ${devFile} )"
if [ ! -d "${locn}" ]
then
${echo} "\tABORT - unable to access '${locn}/' for demo run.\n" >&2 ; exit 1
fi
${echo} "\n DEMO: Creating '${devFile}' to be used as device file ..."
sudo truncate --size 2G ${devFile}
if [ ! -f "${devFile}" ]
then
${echo} "\tABORT - unable to create '${devFile}' for demo run.\n" >&2 ; exit 1
fi
ls -ld ${devFile}
} | awk '{ printf("\t\t%s\n", $0 ) ; }'
### Assign first available 'loop' device
DISK=$(sudo losetup --verbose --find --partscan --show ${devFile} )
${echo} "\n DEMO: Created simulated drive using loop device '${DISK}' ..."
ls -ld ${DISK}
echo ""
df -h -a ${DISK}
#echo "split--"
#mount --verbose | grep ${DISK}
cleanup()
if [ ${doDemo} -eq 1 ]
then
${echo} "\nPurging all elements of demo device ..."
if [ -n "${mounts}" ]
then
#sudo umount --verbose /altboot /altroot /DB008_F2
for mount in $(echo ${mounts} )
do
sudo umount --verbose ${mount}
done
fi
test -n "${DISK}" && { sudo losetup --verbose --detach ${DISK} ; ${echo} "${DISK} detached ..." ; }
test -n "${devFile}" && { sudo rm --verbose --force ${devFile} ; }
${echo} "\tPurged.\n"
fi
trap cleanup EXIT INT TERM
doit=0
doDemo=0
while [ $# -ne 0 ]
do
case "${1}" in
--demo )
doDemo=1
doit=1
shift
--layout )
specifications="${2}"
shift ; shift
--device )
doDemo=0
DISK="${2}"
shift ; shift
--apply )
doit=1
shift ;
esac
done
then
### Specify/Select value for partitioning specifications file
specifications="./partitions_demo_specs.conf"
### Initialize demo processing session
demoSetup
fi
if [ -z "${specifications}" ]
then
echo "\n\t ERROR: File containing specs for device partitioning must be identified using '--layout' flag.\n" ; exit 1
fi
if [ -z "${DISK}" ]
then
echo "\n\t ERROR: Specification of device fullpath required using '--device' flag.\n" ; exit 1
fi
${echo} "\nVerifying the specified disk is recognized and accessible ..."
CMD="testForDisk"
test ${doit} -eq 1 && { ${CMD} ; }
test ${doit} -eq 0 && { echo "DEFERRED: ${CMD}" ; }
########## PHASE I ##########
${echo} "\nEnsuring that the disk has no active dependancy for swap ..."
CMD="testForSwap"
${echo} "\nEnsuring that the disk is not busy or mounted ..."
CMD="unMountDisk"
if [ -n "$(echo ${DISK} | grep -v 'loop' )" ]
then
${echo} "\nScanning '${DISK}' for badblocks before continuing ..."
CMD="sudo badblocks -nsv ${DISK}"
#test ${doit} -eq 1 && { ${CMD} ; }
else
${echo} "\n\tDEMO: Skipping badblocks scan for demo device ..."
fi
########## PHASE II ##########
${echo} "\nStarting Process of Partitioning and Formatting '${DISK}' ..."
${echo} "\nCreate new GPT-type partition table ..."
CMD="sudo parted --script ${DISK} mklabel gpt"
#IFSorig="${IFS}"
specsArray=()
export mount=""
indx=0
grep -v '^#' "${specifications}" |
while [ true ]
do
read specsArray[${indx}]
if [ $? -ne 0 ] ; then break ; fi
test ${doDemo} -eq 1 && { ${echo} "\nINPUT: specsArray[${indx}] = ${specsArray[${indx}]} " ; }
### Parse partition values from command line or configuration file
${echo} "\nExtract partition data from next entry in specifications array ..."
#IFS=':'
read partNum partFsType partStart partEnd partName partMount partFlag <<< "${specsArray[${indx}]}"
${echo} "\n partNum = ${partNum}
partFsType = ${partFsType}
partStart = ${partStart}
partEnd = ${partEnd}
partName = ${partName}
partMount = ${partMount}
partFlag = ${partFlag}"
${echo} "\nCreate a partition to specifications using 'parted mkpart ...' ..."
if [ "${partFlag}" = "null" ]
then
#echo "track1"
CMD="sudo parted --script --align optimal ${DISK} mkpart ${partName} ${partFsType} ${partStart} ${partEnd}"
else
#echo "track2"
CMD="sudo parted --script --align optimal ${DISK} mkpart ${partName} ${partFsType} ${partStart} ${partEnd} set ${partNum} ${partFlag} on"
fi
${echo} "\nUpdate OS awareness of the disk's new structure using 'partprobe' ..."
CMD="sudo partprobe ${DISK}"
sleep 2
${echo} "\nEnsure device node (udev) creation is complete ..."
CMD="udevadm settle"
case ${DISK} in
*loop* )
PARTITION="${DISK}p${partNum}"
/dev/sd* )
PARTITION="${DISK}${partNum}"
esac
${echo} "\nFormat partition to specification ..."
case ${partFsType} in
core )
linux-swap )
CMD="sudo mkswap ${PARTITION} -L '${partName}'"
CMD="sudo mkfs.${partFsType} ${PARTITION} -L '${partName}'"
esac
if [ "${partMount}" != "none" ]
then
if [ ! -d "${partMount}" ]
then
CMD="sudo mkdir ${partMount}"
then
${echo} "\tABORT: Failed to create '${partMount}'.\n" ; exit 1
fi
fi
CMD="sudo mount -t ${partFsType} ${PARTITION} ${partMount}"
RC=0
test ${doit} -eq 1 && { ${CMD} ; RC=$? ; }
if [ ${RC} -eq 0 ]
then
mounts="${mounts} ${partMount}"
else
${echo} "\tABORT: Failed to mount '${PARTITION}' at '${partMount}'.\n" ; exit 1
fi
fi
${echo} "\n\t$(lsblk --paths ${PARTITION} | grep '/dev' )" ;
${echo} "\n\t Hit return to continue ...\c" ; read k <&2
indx=$( expr ${indx} + 1 )
done
#IFS="${IFSorig}"
${echo} "\nReport final state of disk partitioning ...\n"
CMD="sudo parted --script ${DISK} print"
test ${doit} -eq 1 && { ${CMD} | awk '{ printf("\t%s\n", $0 ) }' ; }
echo ""
CMD="sudo lsblk --list --path -o NAME,FSTYPE,PARTLABEL,UUID,SIZE,MOUNTPOINT,SUBSYSTEMS"
test ${doit} -eq 1 && { ${CMD} | grep ${DISK} | awk '{ printf("\t%s\n", $0 ) }' ; }
${echo} "\nReload the updated fstab ..."
CMD="sudo systemctl daemon-reload"
exit 0
exit 0
exit 0
I am also hoping that the Ubuntu Server install will place the correct "grub2 core.img" in that first partition labelled "GRUB". Can anyone confirm if that will be the case?
