AppImage icons on Dock
One of my apps is showing a default icon with a question mark on the dock. Here is the desktop entry:
[Desktop Entry]
Name=Gravit Designer
Comment=gravit-designer
Exec="/home/user1/Documents/GravitDesigner/GravitDesigner.AppImage" %U
Terminal=false
Type=Application
Icon=appimagekit-gravit-designer
StartupWMClass=Gravit Designer
X-AppImage-Version=3.5.6.2893
MimeType=x-scheme-handler/designer;
Categories=Graphics;
X-AppImage-BuildId=1DhTXVWG6um18L87HmdT90s42nF
X-Desktop-File-Install-Version=0.23
X-AppImage-Comment=Generated by /tmp/.mount_GravitYqKxFJ/AppRun
TryExec=/home/user1/Documents/GravitDesigner/GravitDesigner.AppImage
As a workaround, I’d copy the icon(s*) you want to .local/share/icons/ and either name them what’s in the .desktop file ( appimagekit-gravit-designer.XYZ) or change the .desktop file to match your icon’s name.
* If you have multiple sizes, you can make subfolders like 16x16, 32x32 and so on, just make sure the icon files has the correct name.
The icon is already in that folder but it’s not showing up on the Dock.
I've also got a program that show's the default cog-wheel icon in the mate mutiny-style dock. (In the main menu it has the proper icon.) The program is VeraCrypt, which I installed through the Software Boutique.
I'm afraid that I'd need a more step-by-step walkthrough than the above user, as I'm pretty new to Linux - I don't know where I'd find the 'desktop entry' similar to the one tomasantunes posted. But is it possible to go in and change these icons?
Luke
