few days ago i wanted to modify the order of my Apps in the Application Top Bar. Suddenly all apps are gone. The window that i used to edit the Order of Apps does not open anymore and closes 0,1 sec after opening.
Now the Application list is just empty and i have to start my apps through the terminal which sucks.
How could i fix this Problem? Is there a config/xml file in the ubuntumate system that i could change manually to restore the apps?
