Hi folks, new RPi3 owner and new Ubuntu MATE user here. Was lead to this distro because it sounds like exactly what I’ve been looking for.
However, on a fresh install I am doing an ‘apt-get update’ followed by ‘apt-get upgrade’ and it is failing near the end at this part
[email protected]:~# apt-get upgrade
Reading package lists… Done
Building dependency tree
Reading state information… Done
Calculating upgrade… The following packages were automatically installed and are no longer required:
apt-clone archdetect-deb dmeventd dmraid dpkg-repack gir1.2-json-1.0
gir1.2-timezonemap-1.0 gir1.2-xkl-1.0 kpartx kpartx-boot
libdebian-installer4 libdevmapper-event1.02.1 libdmraid1.0.0.rc16
liblvm2cmd2.02 libparted-fs-resize0 libtimezonemap-data libtimezonemap1 lvm2
os-prober python3-icu python3-pam rdate watershed
Use ‘apt-get autoremove’ to remove them.
Done
The following packages have been kept back:
linux-image-rpi2
The following packages will be upgraded:
xserver-xorg-input-wacom
1 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
244 not fully installed or removed.
Need to get 0 B/75.3 kB of archives.
After this operation, 8,192 B disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database … 131148 files and directories currently installed.)
Preparing to unpack …/xserver-xorg-input-wacom_1%3a0.25.0-0ubuntu1.1_armhf.deb …
Unpacking xserver-xorg-input-wacom (1:0.25.0-0ubuntu1.1) over (1:0.25.0-0ubuntu1) …
dpkg: error processing archive /var/cache/apt/archives/xserver-xorg-input-wacom_1%3a0.25.0-0ubuntu1.1_armhf.deb (–unpack):
unable to move aside `./lib/udev/rules.d/69-wacom.rules’ to install new version: Invalid cross-device link
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
How do I proceed? Thanks in advance all
