NEVERMIND - SOLVED: It's engrampa that is responsible for compression/extraction operations from the right-click menu (saw a reference to it in another support post). I reinstalled that and all is well. Leaving this here in case it's helpful for anyone.
Short version: Archive Manager integration to the right-click menu is gone after uninstalling and reinstalling Archive Manager (file roller). Anyone know how to restore this?
Long version: Archive Manager is apparently bundled with p7zip-full now. The existence of p7zip-full will cause password-protected ZIP files created with Archive Manager to use AES encryption, which a lot of Windows clients can't use out of the box. I'm used to uninstalling p7zip-full, but that caused all of Archive Manager to get uninstalled with it (oops). So I reinstalled it. The program works if I open it normally, but all the right-click context menu options are gone (compress/extract). Is there an easy way to bring those right-click menu options back?
