Can one of the experts here tell me (us) how, in some layman’s terms, how THIS translate into some easy install for users of UM 17.04/17.10 ?
Here:
ASUS WebStorage Remote Drive (Linux kernel)
Installation Manual
• Catalog Structure
remotedrive
|--------------dlls
| |-libMonoFuseHelper.so.CentOS32
| |-libMonoFuseHelper.so.CentOS64
| |-libMonoFuseHelper.so.Fedora32
| |-libMonoFuseHelper.so.Fedora64
| |-libMonoFuseHelper.so.openSUSE32
| |-libMonoFuseHelper.so.openSUSE64
|-command.ini
|-install.sh
|-Mono.Fuse.dll
|-Mono.Fuse.dll.config
|-remotedrive.exe
|-start.sh
|-stop.sh
• System requirement:
Mono runtime v.2.10.2
• How to install Mono to CentOS
1. Download Mono v.2.10.2 http://download.mono-project.com/sources/mono/mono-2.10.2.tar.bz2
2. Download libgdiplus-2.10
http://download.mono-project.com/sources/libgdiplus/libgdiplus-2.10.tar.bz2
3. Use root ID to decompress and compile
3. Compile and install libgdiplus
tar -jxvf libgdiplus-2.10.tar.bz2
cd libgdiplus-2.10.tar.bz2
./configure --prefix=/opt/mono
make
make install
echo “/opt/mono/lib” > /etc/ld.so.conf.d/mono.conf
ldconfig
b. Compile and install mono
tar jxvf mono-2.10.2.tar.bz2
cd mono-2.10.2
make
make install
4. Added below environment variables to the bottom layer of /etc/bashrc
export LD_LIBRARY_PATH="/opt/mono/lib:$LD_LIBRARY_PATH"
export C_INCLUDE_PATH="/opt/mono/include"
export ACLOCAL_PATH="/opt/novell/share/aclocal"
export PKG_CONFIG_PATH="/opt/mono/share/pkgconfig:/opt/mono/lib/pkgconfig:$PKG_CONFIG_PATH"
export MANPATH="/opt/mono/share/man:$MANPATH"
export PATH="/opt/mono/bin:$PATH"
5. Use source /etc/bashrc or re-login to load environment setting after finished
• How to install WebStorage Remote Drive
4. tar -zxvf remotedrive.tgz
5. cd remotedrive
6. chmod +x *.sh
7. sudo ./install.sh –run
Note 1: opensuse version needs interactive install (required mono fuse component installation)
Note 2: CentOS version needs to install mono first
• How to start WebStorage Remote Drive
8. Switch to remotedrive catalog
9. sudo ./start.sh <userid> <userpasswd> <PATH>
ex: sudo ./start.sh asuscloud01 00000000 /tmp/ASUSCLOUD
• How to stop WebStorage Remote Drive
10. Switch to remotedrive catalog
- sudo ./stop.sh
And not knowing what would be the actual result and bug free (?) behaviour.
Thx
