This had problems when I tried to reboot or shutdown.
I removed the backlight.desktop file for the CMStorm keyboard.
It seems to be fixed.
Hi @cinema2k,
try booting into an earlier kernel and see if it works, reboot back into your current kernel and mark this as solved if it works okay please!.
I am not for sure if I have an earlier kernel.
Check out the update guide for more info about recovery mode (2nd option in GRUB and choose an earlier kernel):
I rebooted and it has not shown up yet.
Thanks for the link. I will have to study that soon.
