"audacious" not starting with right-click or command line , but root can start at command line !!!
I reinstalled all audacious-related packages, with no effect on the outcome.
- What could be causing this ?
- How can I fix this ?
I found an archive of some Audacious topics so you might be able to find answers to your question there: Recently Active 'audacious' Questions - Ask Ubuntu
One older topic was listed as "Solved" that has something sounding familiar to your issue: " 21.04: Cannot launch Audacious from command line: "D-Bus error: Cannot autolaunch D-Bus without X11 $DISPLAY""
(right-click ? did you config your mouse as left-handed ?)
Any errormessages ? Anything is helpful even if the result is no message at all.
hmm, what is the output of the following command ?
ls -hl $( which audacious )
For UM 22.04 it shoud report:
-rwxr-xr-x 1 root root 211K jan 2 2022 /usr/bin/audacious
and for UM 24.04 it shoud report:
-rwxr-xr-x 1 root root 215K mrt 31 2024 /usr/bin/audacious
-rwxr-xr-x 1 root root 211K Jan 2 2022 /usr/bin/audacious
Not configured for left-click.
No error messages, just no action visible. ![]()
That is weird.
You are on 22.04 LTS ?
If using the full path '/usr/bin/audacious' from the commandline is also not working I'm out of ideas at the moment.
The only thing you could try is to completely purge audacious before installing again:
sudo apt-get purge audacious*
sudo apt autoremove
sudo apt install audacious
I believe that a regular reinstall might skip the already installed binaries when they are installed as dependencies but I might be mistaken.
Starting from command line,
~$ audacious
audacious: runtime.cc:92: MainloopType aud_get_mainloop_type(): Assertion `mainloop_type_set' failed.
Aborted (core dumped)
Holding off on reinstall in case you want me to check something. ![]()
Woops, that looks a bit like a corrupted binary.
I'm totally at a loss here.
audacious -v
should report this version: "Audacious 4.1 (Ubuntu package)"
I guess you have the same version so my previous suggestion still stands.
Could you try to investigate audacious failure using strace? Hopefully, it could catch error condition.
installed audacious on my um24 VM, it runs in X, not command line.
user@um24:~$ audacious -v
Audacious 4.3.1 (Ubuntu package)
user@um24:~$
(for some reason, I cannot paste the screenshot)
Running trace as basic user:
~$ strace audacious
strace audacious
execve("/usr/bin/audacious", ["audacious"], 0x7ffc98871ac0 /* 84 vars */) = 0
brk(NULL) = 0x5dd252acb000
arch_prctl(0x3001 /* ARCH_??? */, 0x7ffcb9e4b240) = -1 EINVAL (Invalid argument)
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x719777617000
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=196347, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 196347, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7197775e7000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libaudcore.so.5", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\340\6\1\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=402392, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 416432, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x719777581000
mprotect(0x719777590000, 319488, PROT_NONE) = 0
mmap(0x719777590000, 221184, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xf000) = 0x719777590000
mmap(0x7197775c6000, 94208, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x45000) = 0x7197775c6000
mmap(0x7197775de000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5c000) = 0x7197775de000
mmap(0x7197775e4000, 10928, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7197775e4000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libgio-2.0.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0\0\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=1928592, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 1938344, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7197773a7000
mmap(0x7197773df000, 1118208, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x38000) = 0x7197773df000
mmap(0x7197774f0000, 548864, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x149000) = 0x7197774f0000
mmap(0x719777576000, 36864, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1ce000) = 0x719777576000
mmap(0x71977757f000, 5032, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x71977757f000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libgobject-2.0.so.0", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=387464, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 392240, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x719777347000
mmap(0x719777356000, 208896, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xf000) = 0x719777356000
mmap(0x719777389000, 106496, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x42000) = 0x719777389000
mmap(0x7197773a3000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5b000) = 0x7197773a3000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libglib-2.0.so.0", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=1277712, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 1282776, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x71977720d000
mprotect(0x71977722a000, 1155072, PROT_NONE) = 0
mmap(0x71977722a000, 585728, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1d000) = 0x71977722a000
mmap(0x7197772b9000, 565248, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xac000) = 0x7197772b9000
mmap(0x719777344000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x136000) = 0x719777344000
mmap(0x719777346000, 728, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x719777346000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libstdc++.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0\0\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=2260296, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 2275520, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x719776e00000
mprotect(0x719776e9a000, 1576960, PROT_NONE) = 0
mmap(0x719776e9a000, 1118208, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x9a000) = 0x719776e9a000
mmap(0x719776fab000, 454656, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1ab000) = 0x719776fab000
mmap(0x71977701b000, 57344, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x21a000) = 0x71977701b000
mmap(0x719777029000, 10432, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x719777029000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=125488, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 127720, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7197771ed000
mmap(0x7197771f0000, 94208, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x7197771f0000
mmap(0x719777207000, 16384, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1a000) = 0x719777207000
mmap(0x71977720b000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1d000) = 0x71977720b000
close(3) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7197771eb000
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0P\237\2\0\0\0\0\0"..., 832) = 832
pread64(3, "\6\0\0\0\4\0\0\0@\0\0\0\0\0\0\0@\0\0\0\0\0\0\0@\0\0\0\0\0\0\0"..., 784, 64) = 784
pread64(3, "\4\0\0\0 \0\0\0\5\0\0\0GNU\0\2\0\0\300\4\0\0\0\3\0\0\0\0\0\0\0"..., 48, 848) = 48
pread64(3, "\4\0\0\0\24\0\0\0\3\0\0\0GNU\0I\17\357\204\3$\f\221\2039x\324\224\323\236S"..., 68, 896) = 68
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=2220400, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 2264656, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x719776a00000
mprotect(0x719776a28000, 2023424, PROT_NONE) = 0
mmap(0x719776a28000, 1658880, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x28000) = 0x719776a28000
mmap(0x719776bbd000, 360448, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1bd000) = 0x719776bbd000
mmap(0x719776c16000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x215000) = 0x719776c16000
mmap(0x719776c1c000, 52816, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x719776c1c000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libgmodule-2.0.so.0", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=22736, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 24712, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7197771e4000
mmap(0x7197771e6000, 8192, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7197771e6000
mmap(0x7197771e8000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x7197771e8000
mmap(0x7197771e9000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x7197771e9000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libQt5Core.so.5", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\320&\f\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=5613992, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 5631360, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x719776400000
mmap(0x71977648e000, 3207168, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8e000) = 0x71977648e000
mmap(0x71977679d000, 1769472, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x39d000) = 0x71977679d000
mmap(0x71977694d000, 61440, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x54c000) = 0x71977694d000
mmap(0x71977695c000, 11648, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x71977695c000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libarchive.so.13", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=821344, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 824968, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x71977711a000
mmap(0x71977712c000, 565248, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x12000) = 0x71977712c000
mmap(0x7197771b6000, 167936, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x9c000) = 0x7197771b6000
mmap(0x7197771df000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc4000) = 0x7197771df000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libm.so.6", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=940560, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 942344, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x719777033000
mmap(0x719777041000, 507904, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe000) = 0x719777041000
mmap(0x7197770bd000, 372736, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8a000) = 0x7197770bd000
mmap(0x719777118000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe4000) = 0x719777118000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libz.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=108936, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 110776, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x719776de4000
mprotect(0x719776de6000, 98304, PROT_NONE) = 0
mmap(0x719776de6000, 69632, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x719776de6000
mmap(0x719776df7000, 24576, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x13000) = 0x719776df7000
mmap(0x719776dfe000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x19000) = 0x719776dfe000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libmount.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=273064, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x719777031000
mmap(NULL, 274984, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x719776da0000
mprotect(0x719776da8000, 237568, PROT_NONE) = 0
mmap(0x719776da8000, 180224, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8000) = 0x719776da8000
mmap(0x719776dd4000, 53248, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x34000) = 0x719776dd4000
mmap(0x719776de2000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x41000) = 0x719776de2000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libselinux.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=166280, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 177672, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x719776d74000
mprotect(0x719776d7a000, 139264, PROT_NONE) = 0
mmap(0x719776d7a000, 106496, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x719776d7a000
mmap(0x719776d94000, 28672, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x20000) = 0x719776d94000
mmap(0x719776d9c000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x27000) = 0x719776d9c000
mmap(0x719776d9e000, 5640, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x719776d9e000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libffi.so.8", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=47688, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 50736, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x719776d67000
mprotect(0x719776d69000, 36864, PROT_NONE) = 0
mmap(0x719776d69000, 28672, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x719776d69000
mmap(0x719776d70000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x9000) = 0x719776d70000
mmap(0x719776d72000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa000) = 0x719776d72000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libpcre.so.3", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=477296, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 479504, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x719776cf1000
mmap(0x719776cf3000, 348160, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x719776cf3000
mmap(0x719776d48000, 118784, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x57000) = 0x719776d48000
mmap(0x719776d65000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x73000) = 0x719776d65000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libdouble-conversion.so.3", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=79952, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 82080, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x719776cdc000
mprotect(0x719776cde000, 69632, PROT_NONE) = 0
mmap(0x719776cde000, 45056, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x719776cde000
mmap(0x719776ce9000, 20480, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xd000) = 0x719776ce9000
mmap(0x719776cef000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x12000) = 0x719776cef000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libicui18n.so.70", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=3328472, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x71977702f000
mmap(NULL, 3334864, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x719776000000
mmap(0x7197760e7000, 1716224, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe7000) = 0x7197760e7000
mmap(0x71977628a000, 598016, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x28a000) = 0x71977628a000
mmap(0x71977631c000, 73728, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x31b000) = 0x71977631c000
mmap(0x71977632e000, 720, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x71977632e000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libicuuc.so.70", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=2062664, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 2073312, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x719775e05000
mmap(0x719775e6b000, 995328, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x66000) = 0x719775e6b000
mmap(0x719775f5e000, 573440, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x159000) = 0x719775f5e000
mmap(0x719775fea000, 81920, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1e4000) = 0x719775fea000
mmap(0x719775ffe000, 4832, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x719775ffe000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libpcre2-16.so.0", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=559816, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 561936, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x719776c52000
mmap(0x719776c54000, 389120, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x719776c54000
mmap(0x719776cb3000, 159744, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x61000) = 0x719776cb3000
mmap(0x719776cda000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x87000) = 0x719776cda000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libzstd.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=841808, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 843832, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x719776331000
mmap(0x71977633b000, 729088, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa000) = 0x71977633b000
mmap(0x7197763ed000, 69632, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xbc000) = 0x7197763ed000
mmap(0x7197763fe000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xcc000) = 0x7197763fe000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libnettle.so.8", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=281000, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 282840, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7197769ba000
mmap(0x7197769c4000, 143360, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa000) = 0x7197769c4000
mmap(0x7197769e7000, 90112, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2d000) = 0x7197769e7000
mmap(0x7197769fd000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x42000) = 0x7197769fd000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libacl.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=34888, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 36896, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x719776c48000
mprotect(0x719776c4a000, 24576, PROT_NONE) = 0
mmap(0x719776c4a000, 16384, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x719776c4a000
mmap(0x719776c4e000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x719776c4e000
mmap(0x719776c50000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x719776c50000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/liblzma.so.5", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=170456, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x71977702d000
mmap(NULL, 172296, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x71977698f000
mmap(0x719776992000, 110592, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x719776992000
mmap(0x7197769ad000, 45056, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1e000) = 0x7197769ad000
mmap(0x7197769b8000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x28000) = 0x7197769b8000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/liblz4.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=125152, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 127072, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x71977696f000
mprotect(0x719776971000, 114688, PROT_NONE) = 0
mmap(0x719776971000, 102400, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x719776971000
mmap(0x71977698a000, 8192, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1b000) = 0x71977698a000
mmap(0x71977698d000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1d000) = 0x71977698d000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libbz2.so.1.0", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=74848, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 76840, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x719776c35000
mmap(0x719776c37000, 53248, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x719776c37000
mmap(0x719776c44000, 8192, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xf000) = 0x719776c44000
mmap(0x719776c46000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x10000) = 0x719776c46000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libxml2.so.2", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=1967384, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 1973720, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x719775c23000
mprotect(0x719775c52000, 1736704, PROT_NONE) = 0
mmap(0x719775c52000, 1388544, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2f000) = 0x719775c52000
mmap(0x719775da5000, 344064, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x182000) = 0x719775da5000
mmap(0x719775dfa000, 40960, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1d6000) = 0x719775dfa000
mmap(0x719775e04000, 3544, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x719775e04000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libblkid.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=220208, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 222128, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x719775bec000
mprotect(0x719775bf3000, 172032, PROT_NONE) = 0
mmap(0x719775bf3000, 131072, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x719775bf3000
mmap(0x719775c13000, 36864, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x27000) = 0x719775c13000
mmap(0x719775c1d000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x30000) = 0x719775c1d000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libpcre2-8.so.0", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=613064, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 615184, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x719775b55000
mmap(0x719775b57000, 438272, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x719775b57000
mmap(0x719775bc2000, 163840, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6d000) = 0x719775bc2000
mmap(0x719775bea000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x94000) = 0x719775bea000
close(3) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x719776c33000
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libicudata.so.70", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=29476472, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 29478936, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x719773e00000
mmap(0x719773e01000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x719773e01000
mmap(0x719773e02000, 29466624, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x719773e02000
mmap(0x719775a1c000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1c1b000) = 0x719775a1c000
close(3) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x719776c31000
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x719776c2f000
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x719776c2d000
arch_prctl(ARCH_SET_FS, 0x719776c30580) = 0
set_tid_address(0x719776c30850) = 6527
set_robust_list(0x719776c30860, 24) = 0
rseq(0x719776c30f20, 0x20, 0, 0x53053053) = 0
mprotect(0x719775a1c000, 4096, PROT_READ) = 0
mprotect(0x719776c16000, 16384, PROT_READ) = 0
mprotect(0x719775bea000, 4096, PROT_READ) = 0
mprotect(0x719775c1d000, 20480, PROT_READ) = 0
mprotect(0x719777118000, 4096, PROT_READ) = 0
mprotect(0x71977720b000, 4096, PROT_READ) = 0
mprotect(0x71977701b000, 45056, PROT_READ) = 0
mprotect(0x719775fea000, 77824, PROT_READ) = 0
mprotect(0x719776dfe000, 4096, PROT_READ) = 0
mprotect(0x7197769b8000, 4096, PROT_READ) = 0
mprotect(0x719775dfa000, 36864, PROT_READ) = 0
mprotect(0x719776c46000, 4096, PROT_READ) = 0
mprotect(0x71977698d000, 4096, PROT_READ) = 0
mprotect(0x719776c50000, 4096, PROT_READ) = 0
mprotect(0x7197769fd000, 8192, PROT_READ) = 0
mprotect(0x7197763fe000, 4096, PROT_READ) = 0
mprotect(0x719776cda000, 4096, PROT_READ) = 0
mprotect(0x71977631c000, 69632, PROT_READ) = 0
mprotect(0x719776cef000, 4096, PROT_READ) = 0
mprotect(0x719776d65000, 4096, PROT_READ) = 0
mprotect(0x719776d72000, 4096, PROT_READ) = 0
mprotect(0x719776d9c000, 4096, PROT_READ) = 0
mprotect(0x719776de2000, 4096, PROT_READ) = 0
mprotect(0x7197771df000, 16384, PROT_READ) = 0
mprotect(0x719777344000, 4096, PROT_READ) = 0
mprotect(0x71977694d000, 53248, PROT_READ) = 0
mprotect(0x7197771e9000, 4096, PROT_READ) = 0
mprotect(0x7197773a3000, 12288, PROT_READ) = 0
mprotect(0x719777576000, 32768, PROT_READ) = 0
mprotect(0x7197775de000, 8192, PROT_READ) = 0
mprotect(0x5dd251c9b000, 20480, PROT_READ) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x719776c2b000
mprotect(0x719777651000, 8192, PROT_READ) = 0
prlimit64(0, RLIMIT_STACK, NULL, {rlim_cur=8192*1024, rlim_max=RLIM64_INFINITY}) = 0
munmap(0x7197775e7000, 196347) = 0
getrandom("\x35\xbf\x2f\x7d\xa0\x95\x9f\x36", 8, GRND_NONBLOCK) = 8
brk(0x5dd252aec000) = 0x5dd252aec000
statfs("/sys/fs/selinux", 0x7ffcb9e4b280) = -1 ENOENT (No such file or directory)
statfs("/selinux", 0x7ffcb9e4b280) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/proc/filesystems", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0444, st_size=0, ...}, AT_EMPTY_PATH) = 0
read(3, "nodev\tsysfs\nnodev\ttmpfs\nnodev\tbd"..., 1024) = 393
read(3, "", 1024) = 0
close(3) = 0
access("/etc/selinux/config", F_OK) = -1 ENOENT (No such file or directory)
futex(0x7197773460a8, FUTEX_WAKE_PRIVATE, 2147483647) = 0
futex(0x71977695bc48, FUTEX_WAKE_PRIVATE, 2147483647) = 0
rt_sigprocmask(SIG_BLOCK, [HUP INT QUIT TERM], NULL, 8) = 0
futex(0x7197775e67b8, FUTEX_WAKE_PRIVATE, 2147483647) = 0
mmap(NULL, 1048576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x719775a55000
readlink("/proc/self/exe", "/usr/bin/audacious", 1048151) = 18
openat(AT_FDCWD, "/usr/lib/locale/locale-archive", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=8321104, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 8321104, PROT_READ, MAP_PRIVATE, 3, 0) = 0x719773600000
close(3) = 0
newfstatat(AT_FDCWD, ".", {st_mode=S_IFDIR|0770, st_size=24576, ...}, 0) = 0
newfstatat(AT_FDCWD, "/home/ericthered", {st_mode=S_IFDIR|0770, st_size=24576, ...}, 0) = 0
brk(0x5dd252b0d000) = 0x5dd252b0d000
eventfd2(0, EFD_CLOEXEC|EFD_NONBLOCK) = 3
write(3, "\1\0\0\0\0\0\0\0", 8) = 8
rt_sigaction(SIGRT_1, {sa_handler=0x719776a91870, sa_mask=[], sa_flags=SA_RESTORER|SA_ONSTACK|SA_RESTART|SA_SIGINFO, sa_restorer=0x719776a42520}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
mmap(NULL, 8392704, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x719772c00000
mprotect(0x719772c01000, 8388608, PROT_READ|PROT_WRITE) = 0
rt_sigprocmask(SIG_BLOCK, ~[], [HUP INT QUIT TERM], 8) = 0
clone3({flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, child_tid=0x719773400910, parent_tid=0x719773400910, exit_signal=0, stack=0x719772c00000, stack_size=0x7ffdc0, tls=0x719773400640} => {parent_tid=[6528]}, 88) = 6528
rt_sigprocmask(SIG_SETMASK, [HUP INT QUIT TERM], NULL, 8) = 0
futex(0x5dd252aeaf40, FUTEX_WAIT, 2147483648, NULL) = 0
mmap(NULL, 8392704, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x719770400000
mprotect(0x719770401000, 8388608, PROT_READ|PROT_WRITE) = 0
clone3({flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, child_tid=0x719770c00910, parent_tid=0x719770c00910, exit_signal=0, stack=0x719770400000, stack_size=0x7ffdc0, tls=0x719770c00640} => {parent_tid=[6532]}, 88) = 6532
mkdir("/home/ericthered/.config/audacious/playlists", 0755) = -1 EEXIST (File exists)
newfstatat(AT_FDCWD, "/home/ericthered/.config/audacious/playlists", {st_mode=S_IFDIR|0755, st_size=4096, ...}, 0) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/charset.alias", O_RDONLY) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/home/ericthered/.config/audacious/config", {st_mode=S_IFREG|0664, st_size=1193, ...}, 0) = 0
openat(AT_FDCWD, "/home/ericthered/.config/audacious/config", O_RDONLY|O_CLOEXEC) = 8
mmap(NULL, 266240, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7197734bf000
newfstatat(8, "", {st_mode=S_IFREG|0664, st_size=1193, ...}, AT_EMPTY_PATH) = 0
read(8, "\n[audacious]\nequalizer_active=TR"..., 4096) = 1193
read(8, "", 4096) = 0
munmap(0x7197734bf000, 266240) = 0
close(8) = 0
openat(AT_FDCWD, "/usr/share/locale/en_CA/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/share/locale/en/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/share/locale-langpack/en_CA/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/share/locale-langpack/en/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
write(2, "audacious: runtime.cc:92: Mainlo"..., 102audacious: runtime.cc:92: MainloopType aud_get_mainloop_type(): Assertion `mainloop_type_set' failed.
) = 102
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x719777616000
rt_sigprocmask(SIG_UNBLOCK, [ABRT], NULL, 8) = 0
gettid() = 6527
getpid() = 6527
tgkill(6527, 6527, SIGABRT) = 0
--- SIGABRT {si_signo=SIGABRT, si_code=SI_TKILL, si_pid=6527, si_uid=1000} ---
+++ killed by SIGABRT (core dumped) +++
Running trace as root (audacious opened window and started playing first song in last playlist). I killed the terminal command with . Not sure how much of this you need (please let me know where to cut back on the messaging):
Thank you for looking at this, Eugene.
Thank you for looking at this, Thom.
I expect the command line to open the Audacious GUI.
Root can open. user cannot. ![]()
Deferring full purge and reinstall until after debugging ! ![]()
I start my VM in gui (not just ssh), I typed audacious, it started with a warning.
audacious is trying to connect to dbus.
my strace
execve("/usr/bin/audacious", ["audacious"], 0x7fffe5189660 /* 25 vars */) = 0
brk(NULL) = 0x622e1d8ec000
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7566853db000
Your third line ARCH_??? not good.
Also, magic numbers don't match.
So, that means a purge and reinstall. Correct?
Or is there anything else that someone wants me to check ?
Sorry for not getting back to you sooner. I did look at those links on AskUbuntu when you first posted them, and they seem to be the same problem, but when I looked at the responses, there didn't seem to be anything of direct usable value. ![]()
There is a curious difference in the two traces of audacious
User's trace
since then audacious loads messages and fails
Root's trace
read(8, "\n[alsa]\nmixer-element=Master\n\n[a"..., 4096) = 279
since then audacious loads its proprietary libraries and works.
My best guess is that user's configuration does not invoke default (and/or correct) equalizer. That well may be the cause of the fault. You can try to backup user's configuration at /home/ericthered/.config/audacious , copy root's configuration at /root/.config/audacious over it and chown that copy. I.e. you can try to replace user's faulty configuration with working root's configuration.
From "~root/.config/audacious, I did
tar cf - . | ( cd "${there}" ; tar xvpf - )
Under ~/.config/audacious, I did the following:
chown -R ericthered:ericthered .
User is now able to start Audacious without issues !!!
I don't know how the user got corrupted, because one day everyting was fine and the next it wasn't, and I hadn't touched equalizers or visualizers in months !!!! Big mystery!
Thank you to all! Much appreciated.
Before anyone asks: NO! I don't have red hair! ![]()
Glad you got your issue fixed !
