I want to record what is coming from the PC speakers with the Linux version of Audacity, but the Device Toolbar doesn't fully appear. Here's a screenshot of the toolbar:
The same settings can be made in Edit > Preferences > Devices, so you don’t really need this toolbar. It’s also possible that selecting them in that dialog may make them appear on the toolbar as well? - I don’t know.
Ok, thank you for that. I also have another problem. I can’t open Audacity; it says that another copy is already running, but it isn’t.
Open a terminal and enter
Code:
killall audacity
If it then opens, my guess would be that it was not correctly shut down by you. I do not have audacity installed, I cannot verify this.
killall audacity
didn’t do anything.
