Hello,
When I playback music in rhythmbox there is erratic “lag” for the fraction for a second every so often. It does play, but it is not a very pleasant experience, as these “lags” disrupt the flow of the music. This is a problem I have observed before on other machines running linux. As I don’t listen to music that often, it is not a deal breaker, but it is annoying when I do listen to music nonetheless.
To be more precise: It concerns playback of files on my computer. Youtube works fine and I don’t use any music streaming services. I listen through 3,5mm sockets. I don’t use bluetooth or anything like that.
(Thanks for this awesome distro. I’ve been distro hopping a lot the last two years and I am very happy with Ubuntu Mate. It has been running for a several weeks and it is my favorite distro so far. Thank you!)
Here some Info on my computer, in case it helps:
.-/+oossssoo+/-. pilou@drongmo
`:+ssssssssssssssssss+:` -------------
-+ssssssssssssssssssyyssss+- OS: Ubuntu 18.10 x86_64
.ossssssssssssssssssdMMMNysssso. Kernel: 4.18.0-13-generic
/ssssssssssshdmmNNmmyNMMMMhssssss/ Uptime: 5 hours, 51 mins
+ssssssssshmydMMMMMMMNddddyssssssss+ Packages: 2590 (dpkg), 14 (snap)
/sssssssshNMMMyhhyyyyhmNMMMNhssssssss/ Shell: bash 4.4.19
.ssssssssdMMMNhsssssssssshNMMMdssssssss. Resolution: 1920x1080, 1920x1080
+sssshhhyNMMNyssssssssssssyNMMMysssssss+ DE: MATE
ossyNMMMNyMMhsssssssssssssshmmmhssssssso WM: Metacity (Marco)
ossyNMMMNyMMhsssssssssssssshmmmhssssssso WM Theme: Ambiant-MATE
+sssshhhyNMMNyssssssssssssyNMMMysssssss+ Theme: Ambiant-MATE [GTK2/3]
.ssssssssdMMMNhsssssssssshNMMMdssssssss. Icons: Ambiant-MATE [GTK2/3]
/sssssssshNMMMyhhyyyyhdNMMMNhssssssss/ Terminal: tilix
+sssssssssdmydMMMMMMMMddddyssssssss+ CPU: AMD FX-4100 (4) @ 3.600GHz
/ssssssssssshdmNNNNmyNMMMMhssssss/ GPU: AMD ATI Radeon RX 460/560D
.ossssssssssssssssssdMMMNysssso. Memory: 2185MiB / 7923MiB
-+sssssssssssssssssyyyssss+-
.-/+oossssoo+/-.
