I need help organizing my panel icons. They don't auto-align and I would like them to. Can someone please help, here is an image of what im talking about:
There's no auto-align function sadly.
You can right click on each launcher and place them as you like and then right click again to pin them to the panel.
As i sugested on IRC earlier: Right click on the icon, select Move to drag it into place and then select Lock To Panel.
Hello,
Well there's a long hard manual method to exactly and equally dispose icons in panel, not just using the eye-method:
Save your panel.
Go to
> usr/share/mate-panel/layout
and find yourpanel.panel
and yourpanel.layout
Back them up.
Inside both files, find the name of every icon and position (ex. 125).
Go increasing this value on every next nearly icon (ex. +20= position 145).
After that, save both files with changes.
Reboot.
It's not an automatic fast method, but is exact and precise.
Cheers
Thank you Tim, very helpful.
