Hello,
This is just for fun, if you're easily bored with a wallpaper and too lazy to manually pick another, then this is for you.
I gathered this from all across the internet. This not only allows you to set a wallpaper through command line but also a random one not sequential. You can also specify your own filter rule for better control!
Without further ado, append the following line to ~/.profile
(that's the home
directory, .profile
file)
gsettings set org.mate.background picture-filename `ls /home/username/Pictures/Wallpapers/*.jpg | shuf -n1`
Replace /home/username/Pictures/Wallpapers/*.jpg
with your own pictures folder and filter rule. Please notice that it's ` not '
Of course you can use the command anytime you want.
Have Fun!
######PS: If you found a Blogger entry with the same guide, it's me unless it's not. I don't steal stuffs, at least not intentionally
