You are right, WD stands for Western Digital. PL are my initials. It was used only for backups of my PC's hard drive. In May it ceased to be normally recognized by the pc. There follows a screenshot I took in early may after trying to use the WD external drive:
Not sure it can be opened. Essentially it says "storage location not available/waiting for 'WD PL' to become connected..."
Today I got a different result. The same external drive is identified as "xxx". On opening, it shows pdf files dating 2020 and a big warning: "The folder contents could not be displayed / Sorry, could not display all the contents of "xxx". Error when getting information for file "/media/cm/xxx/.Trash-1000. Input/output error". I must say that when I started having problems with my WD, I formatted it two or three times.
Using the terminal two commands you suggested gave the following results:
cm@cm-Inspiron-2350:~$ lsblk | grep -i '/media'
└─sdc1 8:33 0 931,5G 0 part /media/cm/xxx
cm@cm-Inspiron-2350:~$ mount | grep -i '/media'
/dev/sdc1 on /media/cm/xxx type vfat (ro,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,showexec,utf8,flush,errors=remount-ro,uhelper=udisks2)
I'm afraid I don't know how to interpret this.
