I do not use backup monitor.
Can I uncheck the box that starts the service ?
You can find it in the MATE Control panel under “Startup applications”.
I wanted to know if I could disable the service for Backup Monitor since I do not use it?
Sure you can. I don’t use it so I unchecked it as well.
Thanks i did.
I go a step further and completely uninstall Deja Dup (Backups) (deja-dup) as I don’t use it either.
sudo apt remove deja-dup
What name do I look for to uninstall Backups ?
Package manager shows a backuppc and backup manager.
Update:
When I uninstalled Deja Dup, the menu entry for Backups disappeared.
