I was a little bored last night while watching Wimpy's World episode ( sorry @Wimpy ) and
found this bash fancy menu on askubuntu
Interesting style of scripting
Fixed some issues, Inputing several keys triggered the menu item and removed/replaced some ANSI escape codes with hexadecimal characters.
The less ANSI the better. On one terminal it's ok but on another makes a mess.
So I thought t would make a good menu for desktopify.
Anyway here's the script:
#!/bin/bash
# Borrowed from https://askubuntu.com/questions/1705/how-can-i-create-a-select-menu-in-a-shell-script
# by oToGamez
# www.pro-toolz.net
E='echo -e';e='echo -en';trap "R;exit" 2
ESC=$( $e "\e")
TPUT(){ $e "\e[${1};${2}H" ;}
CLEAR(){ $e "\ec";}
CIVIS(){ $e "\e[?25l";}
MARK(){ $e "\e[7m";}
UNMARK(){ $e "\e[27m";}
R(){ CLEAR ;stty sane;CLEAR;};
HEAD(){ for each in $(seq 1 15);do
$E " \xE2\x94\x82 \xE2\x94\x82"
done
MARK;TPUT 1 5
$E " DESKTOPIFY " ;UNMARK;
TPUT 2 5
$E " SELECT A DESKTOP ENVIRONMENT " ;UNMARK;}
i=0; CLEAR; CIVIS;NULL=/dev/null
FOOT(){ MARK;TPUT 15 5
$E " UP \xE2\x86\x91 \xE2\x86\x93 DOWN ENTER - SELECT,NEXT ";UNMARK;}
ARROW(){ IFS= read -s -n1 key 2>/dev/null >&2
if [[ $key = $ESC ]];then
read -s -n1 key 2>/dev/null >&2;
if [[ $key = \[ ]]; then
if [[ $key = A ]]; then echo up;fi
if [[ $key = B ]];then echo dn;fi
fi
fi
if [[ "$key" == "$($e \\x0A)" ]];then echo enter;fi;}
M0(){ TPUT 4 20; $e "Lubuntu";}
M1(){ TPUT 5 20; $e "Kubuntu";}
M2(){ TPUT 6 20; $e "Ubuntu";}
M3(){ TPUT 7 20; $e "Ubuntu-Budgie";}
M4(){ TPUT 8 20; $e "Ubuntu-Kylin";}
M5(){ TPUT 9 20; $e "Ubuntu-Mate";}
M6(){ TPUT 10 20; $e "Ubuntu-Studio";}
M7(){ TPUT 11 20; $e "Xubuntu";}
M8(){ TPUT 12 20; $e "EXIT ";}
LM=8
MENU(){ for each in $(seq 0 $LM);do M${each};done;}
POS(){ if [[ $cur == up ]];then ((i--));fi
if [[ $cur == dn ]];then ((i++));fi
if [[ $i -lt 0 ]];then i=$LM;fi
if [[ $i -gt $LM ]];then i=0;fi;}
REFRESH(){ after=$((i+1)); before=$((i-1))
if [[ $before -lt 0 ]];then before=$LM;fi
if [[ $after -gt $LM ]];then after=0;fi
if [[ $j -lt $i ]];then UNMARK;M$before;else UNMARK;M$after;fi
if [[ $after -eq 0 ]] || [ $before -eq $LM ];then
UNMARK; M$before; M$after;fi;j=$i;UNMARK;M$before;M$after;}
INIT(){ R;HEAD;FOOT;MENU;}
SC(){ REFRESH;MARK;$S;$b;cur=`ARROW`;}
ES(){ MARK;$e "ENTER = main menu ";$b;read;INIT;};INIT
while [[ "$O" != " " ]]; do case $i in
0) S=M0;SC;if [[ $cur == enter ]];then R;$e "\n$($e lubuntu)\n";ES;fi;;
1) S=M1;SC;if [[ $cur == enter ]];then R;$e "\n$($e kubuntu)\n";ES;fi;;
2) S=M2;SC;if [[ $cur == enter ]];then R;$e "\n$($e ubuntu)\n";ES;fi;;
3) S=M3;SC;if [[ $cur == enter ]];then R;$e "\n$($e ubuntu-budgie)\n";ES;fi;;
4) S=M4;SC;if [[ $cur == enter ]];then R;$e "\n$($e ubuntu-kylin)\n";ES;fi;;
5) S=M5;SC;if [[ $cur == enter ]];then R;$e "\n$($e ubuntu-mate)\n";ES;fi;;
6) S=M6;SC;if [[ $cur == enter ]];then R;$e "\n$($e ubuntu-studio)\n";ES;fi;;
7) S=M7;SC;if [[ $cur == enter ]];then R;$e "\n$($e xubuntu)\n";ES;fi;;
8) S=M8;SC;if [[ $cur == enter ]];then R;exit 0;fi;;
esac;POS;done
Not sure about the wording.
Is "force desktop package install" close enough?
So save the file in the same dir as desktopify and make executable.
Then cd to that dir and run.
#!/bin/bash
# Wrapper for desktopify Misko_2083
# Menu code adapted from https://askubuntu.com/questions/1705/how-can-i-create-a-select-menu-in-a-shell-script
# Run from the same dir as desktopify
ESC=$( $e "\e")
CLEAR(){ $e "\ec";}
cursor_blink_on() { printf "$ESC[?25h"; }
cursor_blink_off() { printf "$ESC[?25l"; }
done
MARK;TPUT 1 5
TPUT 2 5
$E " SELECT A DESKTOP ENVIRONMENT " ;}
HEAD_II(){ for each in $(seq 1 15);do
done
MARK;TPUT 1 5
TPUT 2 5
$E " SELECT ADDITIONAL OPTIONS " ;
TPUT 4 10
$E " Desktop Environment $1" ;}
i=0; CLEAR; CIVIS;
$E " UP \xE2\x86\x91 \xE2\x86\x93 DOWN \xE2\x94\x82 \xe2\x86\xb5 ENTER - NEXT \xE2\x94\x82 EXIT - X ";UNMARK;}
FOOT_II(){ MARK;TPUT 14 5
$E " \xe2\x86\x90 BACK \xE2\x94\x82 SPACE - SELECT \xE2\x94\x82 ";
TPUT 15 5
read -s -n2 key 2>/dev/null >&2;
if [[ $key = \[A ]]; then echo up;fi
if [[ $key = \[B ]]; then echo dn;fi
fi
if [[ $key = [xX] ]]; then echo exit;fi;
if [[ "$key" = "" ]];then echo enter;fi;}
LM=8
ES(){ INIT;};INIT
MSEL() { cursor_blink_on() { printf "$ESC[?25h"; }
cursor_to() { printf "$ESC[$1;${2:-1}H"; }
print_inactive() { printf "$2 $1 "; }
print_active() { printf "$2 $ESC[7m$1 $ESC[27m"; }
get_cursor_row() { IFS=';' read -sdR -p $'\E[6n' ROW COL; echo ${ROW#*[}; }
key_input() {
local key
IFS= read -rsn1 key 2>/dev/null >&2
if [[ $key = "" ]]; then echo enter; fi;
if [[ $key = [xX] ]]; then echo exit; fi;
if [[ $key = $'\x20' ]]; then echo space; fi;
if [[ $key = $'\x1b' ]]; then
read -rsn2 key
if [[ $key = [A ]]; then echo up; fi;
if [[ $key = [B ]]; then echo down; fi;
if [[ $key = [D ]]; then echo back; fi;
fi;}
toggle_option() {
local arr_name=$1
eval "local arr=(\"\${${arr_name}[@]}\")"
local option=$2
if [[ ${arr[option]} == true ]]; then
arr[option]=
else
arr[option]=true
fi
eval $arr_name='("${arr[@]}")';}
local retval=$1
local options
local defaults
IFS=';' read -r -a options <<< "$2"
if [[ -z $3 ]]; then
defaults=()
else
IFS=';' read -r -a defaults <<< "$3"
fi
local selected=()
for ((i=0; i<${#options[@]}; i++)); do
selected+=("${defaults[i]}")
printf "\n"
done
# determine current screen position for overwriting the options
local lastrow=`get_cursor_row`
local startrow=$(($lastrow - ${#options[@]}))
# ensure cursor and input echoing back on upon a ctrl+c during read -s
trap "cursor_blink_on; stty echo; printf '\n'; exit" 2
cursor_blink_off
local active=0
while true; do
# print options by overwriting the last lines
local idx=0
for option in "${options[@]}"; do
local prefix="[ ]"
if [[ ${selected[idx]} == true ]]; then
prefix="[x]"
fi
cursor_to $(($startrow + $idx))
if [ $idx -eq $active ]; then
if [ $option == OEM ]; then
TPUT $((idx+6)) 6
print_active "$option" "$prefix"
TPUT $((idx+7)) 11
$e "Run a setup wizard on the next boot"
elif [ $option == FORCE ]; then
TPUT $((idx+8)) 6
TPUT $((idx+9)) 11
$e "Force desktop package install"
fi
else
TPUT $((idx+6)) 6
print_inactive "$option" "$prefix"
TPUT $((idx+7)) 11
TPUT $((idx+8)) 6
TPUT $((idx+9)) 11
fi
fi
((idx++))
done
# user key control
case `key_input` in
space) toggle_option selected $active;;
enter) break;;
up) ((active--));
if [ $active -lt 0 ]; then active=$((${#options[@]} - 1)); fi;;
down) ((active++));
if [ $active -ge ${#options[@]} ]; then active=0; fi;;
back) CLEAR; exec $0;;
exit) CLEAR;exit 0;;
esac
done
# cursor position back to normal
cursor_to $lastrow
printf "\n"
cursor_blink_on
eval $retval='("${selected[@]}")'
RUN(){
if [[ $cur != back ]];then
R;HEAD_II "$1"
FOOT_II;
MSEL result "OEM;FORCE" "false;;false"
CLEAR
ARG=
if [[ ${result[0]} == true ]]; then
ARG="--oem"
fi
if [[ ${result[1]} == true ]]; then
ARG="$ARG --force"
fi
$E "sudo ./desktopify $ARG --de $1"
break
fi
cursor_blink_off
while [[ "$O" != " " ]] && [[ $cur != exit ]]; do case $i in
0) S=M0;SC;if [[ $cur == enter ]];then RUN lubuntu; fi;;
1) S=M1;SC;if [[ $cur == enter ]];then RUN kubuntu; fi;;
2) S=M2;SC;if [[ $cur == enter ]];then RUN ubuntu; fi;;
3) S=M3;SC;if [[ $cur == enter ]];then RUN ubuntu-budgie; fi;;
4) S=M4;SC;if [[ $cur == enter ]];then RUN ubuntu-kylin; fi;;
5) S=M5;SC;if [[ $cur == enter ]];then RUN ubuntu-mate; fi;;
6) S=M6;SC;if [[ $cur == enter ]];then RUN ubuntu-studio; fi;;
7) S=M7;SC;if [[ $cur == enter ]];then RUN xubuntu; fi;;
esac;POS;done
CLEAR
cursor_blink_on
It was fun.
