Hi!
I have created a bash script.
It started a program, then it runs.
If I end the program only the program is ended, but not 2 other subordinate program processes.
These do not close automatically.
Is there a possibility if I start my program from my bash script that all other program processes are also automatically closed?
I close the other 2 program processes with another bash script:
#!/bin/sh
pkill 'program name'
exit 0
Is there a way to add my EXIT pkill bash script to my bash script that starts my program?
Something like this:
#!/bin/sh
Run my program:
/path-to/program
After exit my program, execute pkill:
exit 0
Please help, thanks!
have you tried pkill -15 -P ppid or even pkill -9 -P ppid ?
Hi pavlos_kairis,
How should I insert the command pkill -15 -P ppid or pkill -9 -P ppid into my bash script?
#!/bin/sh
/path-to/program
pkill -15 -P ppid
exit 0
The parent pid should be $$
What do you mean by that?
I just found out by accident that this is how it works with my bash script:
#!/bin/sh
/path-to/program
sleep 8m
exit 0
When I close my program, my bash script continues to run.
I then press "Ctrl+c" in the mate terminal to
to end my bash script.
Not the best solution but the 2 other side program processes were also terminated.
the command would be, pkill -15 -P $$
$$ will resolve to the parent pid and pkill will kill all processes with that parent pid sending signal 15
pavlos_kairis:
pkill -15 -P $$
and how should I include this in my bash script?
To which position.
Post times an example, thanks in advance.
Perhaps a better solution would be to use the trap built-in command of bash to do something when the shell script receives a signal or is about to exit for some other reason. Simply insert a line like this at the start of your script that launches another program which fails to clean up after itself, so to speak:
trap 'pkill "program name"' EXIT
So to add it to your original example, the script should look like this:
#!/bin/sh
trap "pkill 'program name'" EXIT
/path-to/program
exit 0
@ Gordon, very nice, wonderful, it works great with that.
Thanks a lot!
- - - S O L V E D - - -
