`bat` - a Modern Replacement for `cat`
How often do we use the cat (conCATenate) command? Well, I happened upon a nifty replacement for it, called bat. Rich with features, including a built-in configurable pager!
sudo apt install bat
On some distros (mine included), the resulting executable is called batcat. But in my .bash_aliases file I simply added alias cat='batcat' and now it works every time I call cat.
It has two help modes, as well: -h for a concise list, and --help for full details.
Read more about it here: https://www.cyberciti.biz/open-source/bat-linux-command-a-cat-clone-with-written-in-rust/
Thanks, Fred.
I’ve been using bat and I definitely cannot go back to cat again. The visual learner in me loves how everything is presented, per se, in a friendly way.
I've even installed bat on my Macs! I use a terminal program (iTerm) frequently and macOS uses zsh by default, and bat works flawlessly there, too!
That’s good to know.
If I can get my super-old Macbook to work, I’ll give it a try.
