Battery Icon Behavior
Ubuntu MATE 16.10 on Toshiba P50 Laptop
After 11/10 daily Software Updater run, the battery charge icon indicates “Laptop Battery Discharging (93.0%)” whether the power supply is plugged in or not. This has remained constant for about 3 hours now.
No battery charging indicated when power supply plugged in.
Multimeter check of power supply indicates 19V output voltage.
Laptop battery charge LED is not lit.
System Tools>Power Statistics shows AC Power connected and 93% battery discharging. This has remained the same for about 3 hours now.
Unplugging power supply is reflected in System Tools>Power Supply but battery charge indication remains at 93%.
Currently running on laptop battery to see if will fully discharge.
BIOS is latest from Toshiba.
UPDATE: Running elementary OS 0.4 from USB stick for A/B comparison.
Battery indicator and laptop charge indicator now function perfectly.
Something changed in MATE 16.10 ?
