in this indicator applet should be nice to see the percentages on the right of the devices names, is it possible?
You can make it show time, percentage or both. I use dconf, but indicators (ayatana indicator power) should work too.
Thank you Jymm for your reply, but that switch has only effect on the main icon on the panel. I'd like to see the percentages for every device listed.
awesome that was what I was trying to get for months!
I don't think that is possible, but if you figure it out, let everyone know.
Yes, for shure. I'm going to post an answer on launchpad.
ok, I posted on Launchpad Answers and they said to post a bug as a Feature Request, I've done it as well .
May be in the next LTS...
I figured it out because the add on panel applet keep crashing or failing to load. If it failed to load I would add a new one and then on a later boot I would have 10+ battery applets. It is a Mate problem. I have had that problem on Debian, Mint, Parrot, Spiral and Sparky. Mint uses ayatana but it still won't work on Mint. The problem started with Mate2. I don't know why it doesn't get fixed, it is very irritating, but at least Ubuntu Mate solved the problem.
In 24.04 they have improved a lot the battery indicator, now I can see the battery level of every device I connect.
