Just FYI, I am attaching here the TLP status:
— TLP 0.8 --------------------------------------------
+++ Configured Settings: /etc/default/tlp
TLP_ENABLE=1
TLP_DEFAULT_MODE=AC
DISK_IDLE_SECS_ON_AC=0
DISK_IDLE_SECS_ON_BAT=2
MAX_LOST_WORK_SECS_ON_AC=15
MAX_LOST_WORK_SECS_ON_BAT=60
SCHED_POWERSAVE_ON_AC=0
SCHED_POWERSAVE_ON_BAT=1
NMI_WATCHDOG=0
ENERGY_PERF_POLICY_ON_AC=performance
ENERGY_PERF_POLICY_ON_BAT=powersave
DISK_DEVICES=“sda sdb”
DISK_APM_LEVEL_ON_AC=“254 254”
DISK_APM_LEVEL_ON_BAT=“128 128”
SATA_LINKPWR_ON_AC=max_performance
SATA_LINKPWR_ON_BAT=min_power
PCIE_ASPM_ON_AC=performance
PCIE_ASPM_ON_BAT=powersave
RADEON_POWER_PROFILE_ON_AC=high
RADEON_POWER_PROFILE_ON_BAT=low
RADEON_DPM_STATE_ON_AC=performance
RADEON_DPM_STATE_ON_BAT=battery
RADEON_DPM_PERF_LEVEL_ON_AC=auto
RADEON_DPM_PERF_LEVEL_ON_BAT=auto
WIFI_PWR_ON_AC=1
WIFI_PWR_ON_BAT=5
WOL_DISABLE=Y
SOUND_POWER_SAVE_ON_AC=0
SOUND_POWER_SAVE_ON_BAT=1
SOUND_POWER_SAVE_CONTROLLER=Y
BAY_POWEROFF_ON_BAT=0
BAY_DEVICE=“sr0”
RUNTIME_PM_ON_AC=on
RUNTIME_PM_ON_BAT=auto
RUNTIME_PM_ALL=1
RUNTIME_PM_DRIVER_BLACKLIST=“radeon nouveau”
USB_AUTOSUSPEND=1
USB_BLACKLIST_WWAN=1
RESTORE_DEVICE_STATE_ON_STARTUP=0
+++ System Info
System = LENOVO Lenovo S20-30 20421
BIOS = ACCN26WW
Release = Ubuntu 15.10
Kernel = 4.2.0-19-generic #23-Ubuntu SMP Wed Nov 11 11:39:30 UTC 2015 x86_64
/proc/cmdline = BOOT_IMAGE=/boot/vmlinuz-4.2.0-19-generic root=UUID=ed9eaae0-1f49-412b-90d4-1baa353009a7 ro quiet splash vt.handoff=7
Init system = systemd
+++ System Status
TLP power save = enabled
power source = battery
+++ Processor
CPU Model = Intel® Celeron® CPU N2840 @ 2.16GHz
/sys/devices/system/cpu/cpu0/cpufreq/scaling_driver = intel_pstate
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor = powersave
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq = 499800 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq = 2582300 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/scaling_driver = intel_pstate
/sys/devices/system/cpu/cpu1/cpufreq/scaling_governor = powersave
/sys/devices/system/cpu/cpu1/cpufreq/scaling_min_freq = 499800 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/scaling_max_freq = 2582300 [kHz]
/sys/devices/system/cpu/intel_pstate/min_perf_pct = 19
/sys/devices/system/cpu/intel_pstate/max_perf_pct = 100
/sys/devices/system/cpu/intel_pstate/no_turbo = 0
x86_energy_perf_policy: program not installed.
/proc/sys/kernel/nmi_watchdog = 0
+++ Undervolting
PHC kernel not available.
+++ Temperatures
CPU temp = 44 [°C]
Fan speed (fan1) = 7 [/min]
+++ File System
/proc/sys/vm/laptop_mode = 2
/proc/sys/vm/dirty_writeback_centisecs = 6000
/proc/sys/vm/dirty_expire_centisecs = 6000
/proc/sys/vm/dirty_ratio = 20
/proc/sys/vm/dirty_background_ratio = 10
/proc/sys/fs/xfs/age_buffer_centisecs = (not available)
/proc/sys/fs/xfs/xfssyncd_centisecs = (not available)
/proc/sys/fs/xfs/xfsbufd_centisecs = (not available)
+++ Storage Devices
/dev/sda:
Model = WDC WD3200LPCX-24C6HT0
Firmware = 02.01A02
APM Level = 128
Status = active/idle
Scheduler = deadline
+++ SATA Aggressive Link Power Management
/sys/class/scsi_host/host0/link_power_management_policy = min_power
/sys/class/scsi_host/host1/link_power_management_policy = min_power
+++ PCIe Active State Power Management
/sys/module/pcie_aspm/parameters/policy = default (using bios preferences)
+++ Intel Graphics
/sys/module/i915/parameters/powersave = (not available)
/sys/module/i915/parameters/enable_rc6 = 1 (enabled)
/sys/module/i915/parameters/enable_fbc = -1 (use per-chip default)
/sys/module/i915/parameters/lvds_downclock = 0 (disabled)
/sys/module/i915/parameters/semaphores = -1 (use per-chip default)
+++ Wireless
bluetooth = on
wifi = on
wwan = none (no device)
wlp2s0(wl) : connected, power management = on
+++ Audio
/sys/module/snd_hda_intel/parameters/power_save = 1
/sys/module/snd_hda_intel/parameters/power_save_controller = Y
+++ Runtime Power Management
device classes = all
device blacklist = (not configured)
driver blacklist = radeon nouveau
/sys/bus/pci/devices/0000:00:00.0/power/control = auto (0x060000, Host bridge, iosf_mbi_pci)
/sys/bus/pci/devices/0000:00:02.0/power/control = auto (0x030000, VGA compatible controller, i915)
/sys/bus/pci/devices/0000:00:13.0/power/control = auto (0x010601, SATA controller, ahci)
/sys/bus/pci/devices/0000:00:14.0/power/control = auto (0x0c0330, USB controller, xhci_hcd)
/sys/bus/pci/devices/0000:00:17.0/power/control = auto (0x080501, SD Host controller, sdhci-pci)
/sys/bus/pci/devices/0000:00:1a.0/power/control = auto (0x108000, Encryption controller, mei_txe)
/sys/bus/pci/devices/0000:00:1b.0/power/control = auto (0x040300, Audio device, snd_hda_intel)
/sys/bus/pci/devices/0000:00:1c.0/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:1c.1/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:1f.0/power/control = auto (0x060100, ISA bridge, lpc_ich)
/sys/bus/pci/devices/0000:00:1f.3/power/control = auto (0x0c0500, SMBus, no driver)
/sys/bus/pci/devices/0000:01:00.0/power/control = auto (0x020000, Ethernet controller, r8169)
/sys/bus/pci/devices/0000:02:00.0/power/control = auto (0x028000, Network controller, wl)
+++ USB
autosuspend = enabled
device whitelist = (not configured)
wwan blacklist = enabled
Bus 002 Device 001 ID 1d6b:0003 control = auto, autosuspend_delay_ms = 0 – Linux Foundation 3.0 root hub (hub)
Bus 001 Device 005 ID 0bda:0129 control = auto, autosuspend_delay_ms = 2000 – Realtek Semiconductor Corp. RTS5129 Card Reader Controller (rtsx_usb)
Bus 001 Device 004 ID 105b:e065 control = auto, autosuspend_delay_ms = 2000 – Foxconn International, Inc. BCM43142A0 Bluetooth module (no driver)
Bus 001 Device 003 ID 05e3:0610 control = auto, autosuspend_delay_ms = 0 – Genesys Logic, Inc. 4-port hub (hub)
Bus 001 Device 002 ID 13d3:5615 control = auto, autosuspend_delay_ms = 2000 – IMC Networks (uvcvideo)
Bus 001 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms = 0 – Linux Foundation 2.0 root hub (hub)
+++ Battery Status
/sys/class/power_supply/BAT1/manufacturer = CPT-ES3
/sys/class/power_supply/BAT1/model_name = LNV-L12C3A01
/sys/class/power_supply/BAT1/cycle_count = 16
/sys/class/power_supply/BAT1/energy_full_design = 23760 [mWh]
/sys/class/power_supply/BAT1/energy_full = 16430 [mWh]
/sys/class/power_supply/BAT1/energy_now = 10380 [mWh]
/sys/class/power_supply/BAT1/power_now = 7150 [mW]
/sys/class/power_supply/BAT1/status = Discharging
