Taking backup of bcm2710-rpi-3-b-plus.dtb.
Installing new bcm2710-rpi-3-b-plus.dtb.
ln: failed to create symbolic link '/boot/dtb-': Operation not permitted
dpkg: error processing package flash-kernel (--configure):
installed flash-kernel package post-installation script subprocess returned error exit status 1
This is the error message with this package. This fails all bundled packages. The isssue is the /boot/dtb- does not exit. What does exist is /boot/dbt-1. This package needs help.
root@astroberry:/home/astroberry# apt-get dist-upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
libgps23 libllvm10 libwcs6
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up flash-kernel (3.98ubuntu12) ...
Using DTB: bcm2710-rpi-3-b-plus.dtb
Installing /etc/flash-kernel/dtbs/bcm2710-rpi-3-b-plus.dtb into /boot/dtbs//./bcm2710-rpi-3-b-plus.dtb
Errors were encountered while processing:
flash-kernel
E: Sub-process /usr/bin/dpkg returned an error code (1)
Hello,
I posted this error on this Package home site. Limited activity is telling me that this problem is not being addressed.
Attempting to move to 21.10 version, this error has never been fixed. Because of the building of Astroberry paradigm, a FAT partition is required. The boot loader is in the FAT partition. This bug attempts to update a symbolic link to this FAT partition. This fails.
IF the symbolic link fails, pick a different source and destination. The symbolic link is looking for the physical. They should not be in the FAT partition.
