What is the best ISO Writing program for Bluray ISOs? I have K3b but anytime I try to load a Bluray ISO it starts loading the ISO but after about 30 seconds the program just closes, with no error message. It will load DVD and CD ISO Images just fine. I have to reboot to Windows 10 and use Image Burn to burn Bluray Discs.
Brasero is another recommended program here on the Ubuntu MATE website: https://ubuntu-mate.org/faq/burn-disc/
It's available in the Software Boutique.
Brasero does not support Bluray Discs
You might try Xfburn. It's relatively new and incomplete, but the website indicates that Xfburn is able to burn ISOs. It might be worth a try.
See the following pages for instructions on how to set up and configure K3b to burn blu-ray ISOs.
https://help.ubuntu.com/community/CdDvd/Burning
Unfortunately I have no direct experience with blu-ray. Good luck daldude.
