Hey all, I have been using the Blue-Submarine theme, and I noticed that on certain applications like Atril Document Viewer, Qbittorrent, and LibreOffice certain parts are on black font color making it hard to read/view.
Some visual examples:
1.Atril Document Viewer page number and zoom level
Yep, I had all of that start to happen. I had to install the "Bluebird" theme to replace "Blue-Submarine." Pretty much the same effect; and all is well, now, regarding those apps you bring up!
Personally I love Windows Border from Blue-Submarine, but mix it with other themes from time to time, till I get bored and try something else, but usually always end up with that windows border
You can change that by clicking Customize on your theme and then get window like @mated posted above and change Controls to something else to your liking. I currently use Arc-Dark from here trough you have few more choices and decide if you like any.
@Cold: You can grab "Bluebird" in a couple of different places if the elderly repo (below) is not up & about.
Here is the stock info --- Version: 0.7.1-7.6 - Groups: System GUI GNOME Size: 27.8 KB License: GPL-2.0+ or CC-BY-SA-3.0
"The Bluebird Theme for GTK2/3 and xfwm4/emerald/metacity started out on the basis of Bluebird, but aims at reworking the intense blue tone to a more neutral blue-ish look that will be more pleasant to look at in everyday use. This package provides the GTK+ 2 support of Bluebird."
After it is installed and useable, go to Applications-Preferences-Appearance-Customize-Colors-Selected items-Backgrounds
BTW, there are some other themes which allow color tweaks - this one just suites me. Most importantly, though, the other thing you must do to get the effect, which it seems you may be wanting, is to tweak the Window title font:
And got it, thanks! The ppa doesn’t seem to work, so it was with git.
Oh, and I wasn’t talking about the window title font on Blue-Submarine. That is fine, its the options below the menu bar that are black and are hard to read. But yeah, need to check out some pretty fonts while I’m there.
