I have an Asus notebook S550C. I installed Ubuntu Linux Mate. The bluetooth does not work. I followed a guide on the internet taken but did not solve the problem. I run the following commands:
lsusb | grep -i "bluetooth"
Bus 001 Device 003: ID 13d3:3362 IMC Networks Atheros AR3012 Bluetooth 4.0 Adapter
hcitool dev
Devices:
rfkill list
0: phy0: Wireless LAN
Soft blocked: yes
Hard blocked: yes
1: asus-wlan: Wireless LAN
Soft blocked: yes
Hard blocked: no
2: asus-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
3: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
sudo /etc/init.d/bluetooth status -l
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: active (running) since sab 2016-10-22 14:51:04 CEST; 25min ago
Docs: man:bluetoothd(8)
Main PID: 1001 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 4915)
CGroup: /system.slice/bluetooth.service
└─1001 /usr/lib/bluetooth/bluetoothd
ott 22 14:50:59 computer64bit-S550CB systemd[1]: Starting Bluetooth service...
ott 22 14:51:00 computer64bit-S550CB bluetoothd[1001]: Bluetooth daemon 5.41
ott 22 14:51:04 computer64bit-S550CB systemd[1]: Started Bluetooth service.
ott 22 14:51:04 computer64bit-S550CB bluetoothd[1001]: Starting SDP server
ott 22 14:51:04 computer64bit-S550CB bluetoothd[1001]: Bluetooth management i...
Hint: Some lines were ellipsized, use -l to show in full.
ls /lib/firmware/ar3k
1020201coex AthrBT_0x31010100.dfu ramps_0x11020000_40.dfu
AthrBT_0x01020001.dfu AthrBT_0x41020000.dfu ramps_0x11020100_40.dfu
AthrBT_0x01020200.dfu ramps_0x01020001_26.dfu ramps_0x31010000_40.dfu
AthrBT_0x01020201.dfu ramps_0x01020200_26.dfu ramps_0x31010100_40.dfu
AthrBT_0x11020000.dfu ramps_0x01020200_40.dfu ramps_0x41020000_40.dfu
AthrBT_0x11020100.dfu ramps_0x01020201_26.dfu
AthrBT_0x31010000.dfu ramps_0x01020201_40.dfu
modprobe -c | grep 3375 | grep ath3k
alias usb:v13D3p3375d*dc*dsc*dp*ic*isc*ip*in* ath3k
computer64bit@computer64bit-S550CB:~$ dmesg | grep -i firmware; dmesg | grep -i bluetooth
[ 0.306315] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 3.534705] psmouse serio4: elantech: assuming hardware version 4 (with firmware version 0x361f03)
[ 3.207898] usb 1-1.1: Product: Bluetooth USB Host Controller
[ 13.682438] Bluetooth: Core ver 2.21
[ 13.682455] Bluetooth: HCI device and connection manager initialized
[ 13.682459] Bluetooth: HCI socket layer initialized
[ 13.682461] Bluetooth: L2CAP socket layer initialized
[ 13.682471] Bluetooth: SCO socket layer initialized
[ 20.437580] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 20.437582] Bluetooth: BNEP filters: protocol multicast
[ 20.437585] Bluetooth: BNEP socket layer initialized
[ 311.561792] Bluetooth: hci0 urb ffffa00c627a40c0 failed to resubmit (113)
[ 311.562166] Bluetooth: hci0 urb ffffa00c627a4b40 failed to resubmit (113)
[ 579.619593] Bluetooth: hci0 urb ffffa00c627a4900 failed to resubmit (113)
[ 579.619966] Bluetooth: hci0 urb ffffa00c627a49c0 failed to resubmit (113)
[ 1073.530716] Bluetooth: hci0 urb ffffa00c5cb4ab40 failed to resubmit (113)
[ 1073.531021] Bluetooth: hci0 urb ffffa00c5cb4a600 failed to resubmit (113)
sudo hciconfig hci0 up
Can't init device hci0: Connection timed out (110)
mynotebook@mynotebook-S550CB:~$ sudo add-apt-repository ppa:hanipouspilot/rtlwifi
[sudo] password di mynotebook:
This is ppa for Realtek drivers from Larry Finger's github.
rtl8192eu is packaged from the Realtek site with some compat patches.
Maggiori informazioni: https://launchpad.net/~hanipouspilot/+archive/ubuntu/rtlwifi
Premere [INVIO] per continuare o Ctrl+C per annullare
gpg: keybox '/tmp/tmp7a_05l5m/pubring.gpg' created
gpg: /tmp/tmp7a_05l5m/trustdb.gpg: creato il trustdb
gpg: chiave 7036069A2F22E44A: chiave pubblica "Launchpad PPA for Pilot6" importata
gpg: Numero totale esaminato: 1
gpg: importate: 1
OK
mynotebook@mynotebook-S550CB:~$ sudo apt-get update
Trovato:1 http://security.ubuntu.com/ubuntu yakkety-security InRelease
Trovato:2 http://it.archive.ubuntu.com/ubuntu yakkety InRelease
Ign:3 http://ppa.launchpad.net/hanipouspilot/rtlwifi/ubuntu yakkety InRelease
Trovato:4 http://it.archive.ubuntu.com/ubuntu yakkety-updates InRelease
Trovato:5 http://it.archive.ubuntu.com/ubuntu yakkety-backports InRelease
Ign:6 http://ppa.launchpad.net/hanipouspilot/rtlwifi/ubuntu yakkety Release
Ign:7 http://ppa.launchpad.net/hanipouspilot/rtlwifi/ubuntu yakkety/main amd64 Packages
Ign:8 http://ppa.launchpad.net/hanipouspilot/rtlwifi/ubuntu yakkety/main i386 Packages
Ign:9 http://ppa.launchpad.net/hanipouspilot/rtlwifi/ubuntu yakkety/main all Packages
Ign:10 http://ppa.launchpad.net/hanipouspilot/rtlwifi/ubuntu yakkety/main Translation-en
Ign:11 http://ppa.launchpad.net/hanipouspilot/rtlwifi/ubuntu yakkety/main Translation-it
Ign:12 http://ppa.launchpad.net/hanipouspilot/rtlwifi/ubuntu yakkety/main Translation-it_IT
Err:7 http://ppa.launchpad.net/hanipouspilot/rtlwifi/ubuntu yakkety/main amd64 Packages
404 Not Found
Lettura elenco dei pacchetti... Fatto
W: The repository 'http://ppa.launchpad.net/hanipouspilot/rtlwifi/ubuntu yakkety Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: Impossibile recuperare http://ppa.launchpad.net/hanipouspilot/rtlwifi/ubuntu/dists/yakkety/main/binary-amd64/Packages 404 Not Found
E: Impossibile scaricare alcuni file di indice: saranno ignorati o verranno usati quelli vecchi.
Trovato:1 http://it.archive.ubuntu.com/ubuntu yakkety InRelease
Trovato:2 http://security.ubuntu.com/ubuntu yakkety-security InRelease
Trovato:3 http://it.archive.ubuntu.com/ubuntu yakkety-updates InRelease
Ign:4 http://ppa.launchpad.net/hanipouspilot/rtlwifi/ubuntu yakkety InRelease
Ign:7 http://ppa.launchpad.net/hanipouspilot/rtlwifi/ubuntu yakkety/main i386 Packages
Ign:8 http://ppa.launchpad.net/hanipouspilot/rtlwifi/ubuntu yakkety/main amd64 Packages
Ign:10 http://ppa.launchpad.net/hanipouspilot/rtlwifi/ubuntu yakkety/main Translation-it_IT
Ign:12 http://ppa.launchpad.net/hanipouspilot/rtlwifi/ubuntu yakkety/main Translation-en
Err:7 http://ppa.launchpad.net/hanipouspilot/rtlwifi/ubuntu yakkety/main i386 Packages
404 Not Found
E: Impossibile recuperare http://ppa.launchpad.net/hanipouspilot/rtlwifi/ubuntu/dists/yakkety/main/binary-i386/Packages 404 Not Found
sudo apt-get upgrade
Generazione albero delle dipendenze
Lettura informazioni sullo stato... Fatto
Calcolo dell'aggiornamento... Fatto
I seguenti pacchetti sono stati mantenuti alla versione attuale:
linux-generic linux-headers-generic linux-image-generic linux-tools-generic
0 aggiornati, 0 installati, 0 da rimuovere e 4 non aggiornati.`
Tips solutions?
See you soon.
